Tachometer doesn't work
I just got a 1992 Integra ls and my tachometer gauge doesn’t work, my other gauges work, but I was wondering if there is anyway I could find out why it is not working before I decide if I am going to buy a new tach or gauge cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =p »</TD></TR><TR><TD CLASS="quote">You might want to check your VSS (vehicle speed sensor) as well.</TD></TR></TABLE>
why? if you read his post all his other gauges work.
when i get home i'll look in my helms. there are a few tests to do for tach function.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports »</TD></TR><TR><TD CLASS="quote">
when i get home i'll look in my helms. there are a few tests to do for tach function. </TD></TR></TABLE>
I take it back. I misread the question.
What I meant to say was check the distributor and ignition coil inside of the distributor.
If youre planning to change your cluster later on in the future minus well do it now rather than get a new tachometer only to change it later down the road. Unless you can fix it.
Not sure if that made sense or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oOoBanana »</TD></TR><TR><TD CLASS="quote">If youre planning to change your cluster later on in the future minus well do it now rather than get a new tachometer only to change it later down the road. Unless you can fix it.
Not sure if that made sense or not.</TD></TR></TABLE>
i think i understand what you are saying. And if i can fix my tach im going to keep it like that, but if i can't im just going to go with a aftermarket one. But i would really like to keep the stock tach because i would rather spend the money on a different part, and i don't like having a gauge that doesn't work.
yeah. well good luck with ur decision. if i was you i'll probably end up pounding my tach until it works. HAHA but yeah thats just how i do things. pound on it until it breaks then i sit there and cry after.
krazieV
Aug 7, 2008 08:43 PM
JDM_rolex
Jul 23, 2006 11:49 AM
