Tach Problem after OBD2 to OBD1 Change!!!
Old Apr 3, 2003 | 05:52 AM
GorData's Avatar
Default Tach Problem after OBD2 to OBD1 Change!!!
Whats the deal people!
My boy has a 2000 GSR and we bought obd2 to obd1 plugs and p28 Chipped and now when we rev his car starts good and then right after 5000 it drops right down to 0 and then catches up again to where ever the RPM Are suppose to be, I check the ECU and The plugs on different Car and it doesnt do it, Changed just the computer and still does it but it doesnt do it with the Factory Computer.
Old Sep 28, 2005 | 03:45 PM
advert's Avatar
Default Re: Tach Problem after OBD2 to OBD1 Change!!! (GorData)
bump from the dead. did you you ever fix this. i also have a 2k gsr and it has the same problem when i converted
Old Sep 28, 2005 | 09:29 PM
advert's Avatar
updata tried hooking a external tach up no go. freaks out. also tried hooking up to my zeitronic data loger no go it thinks i am at like 300,000 rpms! surely someone else has had this same problem
Old Sep 28, 2005 | 10:13 PM
fergy016's Avatar
is the p28 chipped, what program are you using to tune with?
Old Sep 28, 2005 | 10:33 PM
verbol assassin's Avatar
Default Re: (fergy016)
i have an obdII ecu for sale.
Old Sep 29, 2005 | 04:54 PM
advert's Avatar
yea chipped with uberdata and a ostrich
Old Sep 29, 2005 | 09:43 PM
advert's Avatar
alright i fixed the problem. i know more people will have this problem. it seems to be on 00-01 integras there was no wire from the dizzy run to the ecu. all you have to do is hard wire a pin from the dizzy to the ecu and it fixes the problem. i did not think this could be the problem at first cause the cluster went up a lil than died but it fixed it. i hope this helps someone else some day
Old Feb 22, 2012 | 06:08 PM
00DC2-itr's Avatar
I know this is old but I just bought a car and it is doing the same thing. So you just ran a wire from where to where locations please a little bit more specific thank you or message me the info or text to 509-969-0669
808jdm_profileEG6
Engine Management and Tuning
Aug 4, 2009 08:20 PM
sevenfc
Feb 25, 2009 12:43 PM
frstbte14
May 31, 2007 01:22 PM
maddcao
Nov 29, 2006 07:58 PM
ls95hatch
Jul 17, 2003 02:13 AM
