tach jumping?
Old Apr 29, 2007 | 01:11 PM
emooheo's Avatar
Default tach jumping?
I was driving my GSR today and decided to punch it on the freeway. I have noticed when taking off from first gear it is pretty gutless until it hits vtec then you can feel it pull.
I downshifted into third and was at about 4000 rpms, give it WOT hit vtec and at about 6500 rpms the tach starts acting very strange. It will go to 6500 and stay there, then in a few seconds hit like 7500 then 8k. It is only noticeable in third or higher gears but after doing a first gear run it seemed to do it too, but not as noticeable because the gear is so much shorter.
What do you guys think the problem could be?
thanks
Old Apr 29, 2007 | 01:35 PM
adip315's Avatar
Default Re: tach jumping? (emooheo)
Is just the tach jumping or is your motor struggling in those rpm ranges?
Old Apr 29, 2007 | 01:48 PM
emooheo's Avatar
the motor sounds normal to me, it may be struggling though. i bought the car used and havent done a tune up yet. Could that possibly be the problem? plugs/wires/cap/rotor
Old Apr 29, 2007 | 01:55 PM
adip315's Avatar
Default Re: (emooheo)
Any cels? Could be a misfire
Old Apr 29, 2007 | 02:12 PM
emooheo's Avatar
no cel's.. and its obd1. i think that i'm going to do a tune up and see what happens.
Old Apr 29, 2007 | 07:13 PM
motoman's Avatar
This is a common problem with integras. Check your grounds for the ecu, and also check the insulation on the wires coming from distributor.
Old Apr 29, 2007 | 08:18 PM
98AcurHondaNsx's Avatar
Default Re: tach jumping? (motoman)
i had that problem with my ls vtec it was my distributor
Old Apr 29, 2007 | 09:19 PM
blacK_Dc4's Avatar
Default Re: tach jumping? (98AcurHondaNsx)
check connections on the igniter inside the distributor
citrus3000psi
May 29, 2007 12:45 PM
copeman
Dec 1, 2006 04:48 PM
JasonST
Aug 24, 2006 05:08 PM
force-fed
May 9, 2006 05:05 PM
cxSHOE
Aug 14, 2004 07:55 PM
