switch gas
Old Feb 2, 2002 | 04:58 PM
csfalcon's Avatar
Default switch gas
Hi all,
I have been using premium 93 oct, is it ok to switch to regular 87 oct? should I use plus 89 oct for a while before I do the switch? $$$
thanks
Old Feb 2, 2002 | 05:02 PM
VTi NA's Avatar
Default Re: switch gas (csfalcon)
Unless you have a GSR or one decently modded LS, you sould be using the lower grades anyways.
Old Feb 4, 2002 | 08:29 AM
Rtzx9r's Avatar
GDD 1%
Default Re: switch gas (STi -RA)
Yes you can switch between them w/ no problem.
Old Feb 4, 2002 | 08:33 AM
Slick GS-R's Avatar
Default Re: switch gas (Rtzx9r)
you can use either, but i would stick with 89..........there is no advantage to putting a higher octane gas unless you are running n2o or something like that
Old Feb 4, 2002 | 09:45 AM
o_Rage_o's Avatar
Default Re: switch gas (Slick_GS-R)
You run higher octane if the lower octane knocks, provides with rough idle, or engine run on.
It's not necessary to run higher octane, but it does give better mileage and response, and should be used on GSR + or a heavy modded ls/rs
It also keeps your engine running cleaner, and in canada, usually has more additives...like winter gas or tactrol
[Modified by o_Rage_o, 6:45 PM 2/4/2002]
Old Feb 4, 2002 | 09:49 AM
HaUTSaauce's Avatar
New User
what type of mods do u have with your car?
Old Feb 4, 2002 | 02:14 PM
Slick GS-R's Avatar
Default Re: switch gas (o_Rage_o)
... it does give better mileage
this is not true
Old Feb 4, 2002 | 03:41 PM
Calavera's Avatar
Seeing that you have a GS, I wouldn't bother putting in 91+ octane gas in it. Unless you're GS is heavily modded like FI or advanced timing, running 89 is just fine.
Old Feb 4, 2002 | 03:45 PM
Erik_Pb_Foot's Avatar
New User
My idle was much better with 93, and it was a little more responsive (not enough to constitute buying it though).... if your engine can't burn it all you will have more carbon deposits is what i was told... don't know if its true though. If you are @ a junky gas station for SOME ODD REASON, I would get plus or premium just to be on the safe side... but I wouldn't go to a gas station aside from Amoco/BP... we don't have Sunoco's near me....
Old Feb 4, 2002 | 05:29 PM
Rtzx9r's Avatar
GDD 1%
Default Re: switch gas (Pb_Foot)
Pb foot- cool name.
I only buy BP. Why? Shell pay at the pumps are always broken, and all the rest suck. I have not set foot in a gas station in years...waitin in line to pay behind the "I need 4 cartons of cancer-sticks and $40 worth of lotto tix" It is the 21st century..no pay at the pump, no deal.
Lottery= A game for people who are bad in mathematics.
Old Feb 4, 2002 | 06:14 PM
Slick GS-R's Avatar
You should also use higher octane gas if your timing has been changed from stock settings...
jumpin4abeat
Jul 27, 2011 07:32 PM
smoked08
Apr 13, 2011 02:17 PM
hello1320
Sep 21, 2010 05:34 AM
vegaspartyy
Jul 25, 2006 06:46 PM
honda_accord_215
Jun 16, 2006 12:51 PM
