Swapping a Door
Old Feb 9, 2005 | 01:31 PM
bg-33p's Avatar
Default Swapping a Door
hey, i was just wondering how hard it would be to swap a door from a 94 gsr.
im doing this because my old door has a lot of dents and i just found someone selling a door the same exact color for pretty cheap..
thanks in advance
Old Feb 9, 2005 | 02:59 PM
bg-33p's Avatar
Default Re: Swapping a Door (teggysue)
please helppp
Old Feb 9, 2005 | 03:34 PM
Deluzional's Avatar
Well basically, first thing you do is pull of your door panel. Then disconnect all the plugs/harnesses(1 plug is going to be a bitch to remove, its located near the hinges). Then loosen the 2 bolts and your door should come off. Swap everything in reverse order.
I advise you do seek assistance from a friend, because itll be difficult to bolt your door up alone. Make sure you allign it so it opens and closes properly
Old Feb 9, 2005 | 03:48 PM
Mordeki's Avatar
Abusing my rights one day at a time.
Default Re: Swapping a Door (Deluzional)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">Well basically, first thing you do is pull of your door panel. Then disconnect all the plugs/harnesses(1 plug is going to be a bitch to remove, its located near the hinges). Then loosen the 2 bolts and your door should come off. Swap everything in reverse order.
yes, make sure it lines up PERFECTLY or you will have leaks or worse
Old Feb 9, 2005 | 03:50 PM
AlphaQup's Avatar
^^ what Deluzional said. Only thing he forgot was to mention the little pin that holds the flat metal peice between the hinges. Just tap it out from the bottom.
Old Feb 9, 2005 | 03:58 PM
bg-33p's Avatar
Default Re: Swapping a Door (AlphaQup)
thanks guys..
bebfsu1
Jan 6, 2007 10:28 AM
sleepingcivic90
Jan 16, 2005 05:52 PM
SPOONup
Apr 13, 2004 08:00 PM
kniob
Mar 27, 2004 03:06 PM
