swap question
Old Jan 13, 2004 | 12:34 PM
mattL's Avatar
Default swap question
I'm about to be changing out my motor and i had a couple questoins. its a straight forward swap, i'm taking out my Gsr and replacing with another Gsr. the thing is that i've never done a swap in an integra, only on civics. is there anything i should know when dealing with the power steering ABS or other things that arent on a civic? any sites that have a good breakdown of the swap? thanks
Old Jan 13, 2004 | 01:56 PM
Blue Streak's Avatar
Default Re: swap question (mattL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattL &raquo;</TD></TR><TR><TD CLASS="quote">I'm about to be changing out my motor and i had a couple questoins. its a straight forward swap, i'm taking out my Gsr and replacing with another Gsr. the thing is that i've never done a swap in an integra, only on civics. is there anything i should know when dealing with the power steering ABS or other things that arent on a civic? any sites that have a good breakdown of the swap? thanks</TD></TR></TABLE>
everything is pretty much straight forward if your replacing with the same motor. if youve done civics before integra almost the exact same.
Old Jan 13, 2004 | 02:13 PM
Boofster's Avatar
Default Re: swap question (Blue Streak)
The rear mount bracket is a pain. Other than that, straight forward. Watch that TPS sensor as usual...it will hit the fuel filter.
Keangdawizes
Oct 15, 2008 04:55 AM
ThatGreenGsr
Dec 30, 2007 06:05 PM
