Swap Help.?.?
Old Jan 16, 2010 | 07:40 PM
94lsDC2's Avatar
Default Swap Help.?.?
hey guys i have a 94 integra ls body im wanting to swap a jdm itr and im needing help on what im going to need and do. plz help....
Old Jan 17, 2010 | 12:53 PM
punxsk8r555's Avatar
Default Re: Swap Help.?.?
I have a 94 ls and swaped the jdm b18c in bout 6 months ago. just get your motor and tranny and all that good stuff. make sure you got a good ecu for it like a chipped p28 tuned for the type r. or get the conversion harness from obd1 to obd2 so you can use the stock type r ecu but that part will cost just as much as a good p28 so i would do that. swap the motor in and plug the harness in. then you will have to run your vtec wire from the solenoid to your ecu, the knock sensor will have to be run to your ecu and then out of the ecu the wire for your vtec pressure switch will have to be grounded. i forgot the exact placement of those 3 wires coming out of your ecu but i found it on HT so look that part up. you gotta run those wires since the ls isnt set up for vtec.
luvmihatch
Oct 5, 2008 10:34 AM
94IntegraLs04
Aug 31, 2005 07:53 PM
94IntegraLs04
Aug 10, 2005 09:13 PM
slammedteg
May 1, 2004 09:12 AM
KRiS1
Jul 3, 2003 07:03 PM
