Suspension between DA and DC ?
Old Mar 3, 2004 | 04:29 AM
MikeTV
Guest
Posts: n/a
Default Suspension between DA and DC ?
Can someone use Eibach springs made for a DA chassis on a DC chassis ? Does anyone know what the differences are between the suspension of the two ?
Old Mar 3, 2004 | 04:39 AM
Creep's Avatar
Default Re: Suspension between DA and DC ? (Eclipse spanker)
The components are not really interchangable, but you can get them to work.
To use springs off a DC or an EG you will need the front struts and front drop forks.
The diameter of the DC strut is larger so it wont fit in your DA fork. The perches
on the DA and DC front struts are at different heights. In the rear you can use
either the DA or DC strut.
Theres a write up on g2ic that explains this in detail.
In short, its not really worth it, they are totaly two different chassis... It's hard to
determine what a 2" DC drop will look like on a DA. Or vice - versa.
I've had some EG suspension components on my DA, but its sorta hit or miss. You
basically try it and see what it does.
Old Mar 3, 2004 | 05:53 AM
MikeTV
Guest
Posts: n/a
Default Re: Suspension between DA and DC ? (Creep)
cool, thanks alot bro
Old Mar 3, 2004 | 06:26 AM
DA Teg D00D's Avatar
what about using DC shocks specifically on the rear of the DA...b/c they don't make DA specific KYB AGX shocks so i was wondering if we could use the KYB for the DC....?
Old Mar 3, 2004 | 11:09 AM
Creep's Avatar
Default Re: (DA Teg D00D)
They will bolt up, but I can't verify that the perch
height is the same. I'm pretty sure it is.
Then there is the problem of the two cars having different weights.
Old Mar 3, 2004 | 01:53 PM
Default Re: (Creep)
anyone know of this? anyone done it? DC shocks on a DA that is...
MIDNIGHTTUNER
Mar 16, 2017 10:13 AM
eastbayrep
Jan 3, 2010 03:33 PM
h23vtecDA
Sep 12, 2007 07:04 PM
Blacklabel182
Suspension & Brakes
Oct 5, 2006 10:11 PM
Teglessb18
Dec 22, 2005 04:07 PM
