Surging Idle
Old Dec 3, 2006 | 07:49 PM
Mr_Moos's Avatar
Default Surging Idle
Searched found nothing
Motor LS/vtec B16 head
Idle is surgeing between 1100 to 2000
Sometimes settles to 1100 randomly
idle control screw I turned down as low as it will go still idles at 1100
IACV might be from LS would that matter
Checked air bubbles in radiator
Checked vacuum lines
No Codes..
What else to check?
Old Dec 3, 2006 | 08:10 PM
JasonST's Avatar
Default Re: Surging Idle (Mr_Moos)
Try cleaning ur IACV and ur FITV. Do a search on eather one and u'll get plenty of threads on how to clean em if u need help.
Old Dec 3, 2006 | 08:33 PM
Mr_Moos's Avatar
Default Re: Surging Idle (JasonST)
Was told I dont have a FITV car is a 99
Do IACV go bad? Should I try replacing it?
Old Dec 3, 2006 | 08:58 PM
Blk-dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">Try cleaning ur IACV and ur FITV. Do a search on eather one and u'll get plenty of threads on how to clean em if u need help.</TD></TR></TABLE>
are you sure your b16 don't have a FITV, i think it might.....
my 95 gsr has one and it used to surg like that, then i replaced it and it stop....
Old Dec 3, 2006 | 09:54 PM
Mr_Moos's Avatar
Default Re: Surging Idle (BLACK-dc2)
not sure im using a 99 ls throttle body
anyone know if 99 ls have FITV?
Old Dec 4, 2006 | 04:48 AM
cinabarDA's Avatar
look right under your throttle body if you see a valve there with two cooling looking lines going in and out of it that is your fast idle valve take the backing plate off of it it should be two screws/8 mm's once you have done that there will either be a flat head screw in there or a white ring with two slots in it make sure you screw that in tight then put it all back together and start your car hope that works for you.
Old Dec 4, 2006 | 06:39 AM
Cablerat's Avatar
If your FITV is in a rough shape, it'll cause idle surges even once the car is warmed up.
SuperSlowEF8
11
Sep 17, 2011 04:00 PM
Pure Sol
16
Dec 31, 2007 12:06 PM
alghafat424
Nov 13, 2006 01:29 AM
4ghatch
Sep 28, 2005 02:59 AM
94SHOWLS
Feb 17, 2005 12:31 PM
