stupid question
Old Oct 27, 2006 | 06:40 AM
southcoast integra's Avatar
Default vtec question
how exactly does it work?
Modified by southcoast integra at 7:58 AM 10/27/2006
Old Oct 27, 2006 | 06:58 AM
huevosrancheros's Avatar
Default Re: stupid question (southcoast integra)
LOL, Search little one, search. Go to hondatuningmagazine.com and read up on it.
Old Oct 27, 2006 | 10:40 AM
95 integra's Avatar
Default Re: stupid question (huevosrancheros)
It applies electric shock to the hamster
Heres a decent video of it.....
http://www.youtube.com/watch?v...=vtec
http://asia.vtec.net/spfeature/vtecimpl/vtec1.html
Old Oct 27, 2006 | 12:48 PM
rotorhead's Avatar
Default Re: vtec question (southcoast integra)
doesnt a port open up at mid range rpms to let more air in??
Old Oct 27, 2006 | 01:48 PM
95 integra's Avatar
Default Re: vtec question (rotorhead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rotorhead &raquo;</TD></TR><TR><TD CLASS="quote">doesnt a port open up at mid range rpms to let more air in??</TD></TR></TABLE>
Only on the GSR and at 6k which is in the "upper" rpm band, mid is generally referred to from 3k-5/5.5k. The type R does away with that (along with aftermarket intakes), the H22 has it, but the RSX-S does not (the RSX base does as well though).
Old Oct 27, 2006 | 06:33 PM
rsgard's Avatar
Default Re: vtec question (95 integra)
Since i have a gsr i will use those numbers
First off the car has to be at operating temperature and be moving, reving in the driveway will not cause vtec to engage. Oil pressure must also be normal.
at 4600 rpms the ecu sends a signal to the vtec solenoid which allows oil pressure to move a pin type thing to engage the vtec lobes on the camshaft which have greater lift and duration than the other lobes. At 5800 rpms a senor that senses vacuum pressure is set to trigger the secondary runners on the intake manifold to open up. The secondaries open so that the torque curve remains relatively straight. All memorized from the school of T-I
Old Oct 27, 2006 | 08:46 PM
95 integra's Avatar
Default Re: vtec question (rsgard)
Vtec engages at 4400 (stock gsr, actually varies to some degree depending on engine load, temp and probably some other factors)
Secondaries open at 5950
itc11
May 17, 2007 10:54 AM
fLipbaLLer32
Sep 20, 2005 07:57 AM
excel88
May 28, 2004 11:01 PM
1Quikgsr
Feb 16, 2004 10:50 AM
BoostedD15B7
Feb 10, 2004 05:00 AM
