stumped
Hey guys I have b18 that is idling rough but still gets good mpg (30) and has good power I'm losing oil and coolent but my car only smokes on startup after being run for an extended period its hard to start and smokes for a few seconds.
Compression test reveled 150-175-75-150 I'm thinking head gasket combined with valve stem seals how about you guys? I have head bolts and a full gasket kit. Other suggestions ? Ideas? Oil has never been milky and is changed every 3-3.6k
No, likely the gasket but it's a good idea to check while it's apart to be sure instead of replacing the gasket only to find out the head is warped beyond the new gaskets thickness or causing premature failure of the new gasket
If the compression test was done properly (with all plugs out) then b swapped is right about the valve, I'm not sure if rings are a factor here but the wet compression test can't hurt
