STR block saver???
Old Jan 29, 2004 | 05:51 PM
sPaRk'iT's Avatar
Default STR block saver???
Are they worth it?? i going b20/boosted, i dont want to resleeve my block anytime soon, and i heard that this STR block saver can help?? Any of you guys have experience with them??
Old Jan 29, 2004 | 05:55 PM
LSTEG96's Avatar
Default Re: STR block saver??? (sPaRk'iT)
i doin ls/vtec, plan to rev, i bought one... peace of mind???
Old Jan 29, 2004 | 07:39 PM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
i'm also wondering before i purchase for 81.5mm ls/vtec
Old Jan 30, 2004 | 12:20 AM
sPaRk'iT's Avatar
Default Re: STR block saver??? (LSTEG96)
anybody else?
Old Jan 30, 2004 | 12:23 AM
jDMJeRk's Avatar
are you guys tlaking about block guards? or is this something else....
Old Jan 30, 2004 | 10:22 AM
sPaRk'iT's Avatar
Default Re: STR block saver??? (jdmjerk)
i dont know, all i know is that its call a block saver, and its suppose to help.
check it out, http://www.strpower.com/strblocksaveintro.htm
Modified by sPaRk'iT at 7:47 PM 1/30/2004
Old Jan 30, 2004 | 11:04 AM
jDMJeRk's Avatar
yeah those are block guards i got one for race engeering for 106 shipped
I was told one guy had problems with it over heating but the machine shop i went to says they are good guards so Im going to try it out
Old Jan 30, 2004 | 11:29 AM
l2Y4N's Avatar
check out Golden Eagle block gaurds, they have better cut outs, to prevent the overheating problem.
Old Jan 30, 2004 | 11:56 AM
riceball777's Avatar
i never had one but i head a lot of bad things about them. about how they really dont help and are a waste of money and cause hot spots on the sleeves, causing the engine to over heat
Old Jan 30, 2004 | 02:01 PM
Rayman's Avatar
Default Re: STR block saver??? (riceball777)
When you plan on shooting 150 shot of nitrous. It helps.
Old Jan 30, 2004 | 02:06 PM
Tweakmeister's Avatar
Default Re: STR block saver??? (Rayman)
why not do things right the first time? (sleeve)
Old Jan 30, 2004 | 04:24 PM
BseriesHatch's Avatar
I also have a b20 and wanted to get one. I found on that looks close to the STR one and is way cheaper. http://www.azracemachine.com/BlokGardDesc.htm. You can't beat $80!
Old Jan 30, 2004 | 06:18 PM
sPaRk'iT's Avatar
hhmm/...i really need more info then that?
Old Jan 30, 2004 | 09:27 PM
D@nnY's Avatar
They make good paper weights. or you can put them in your motor and warp your block or melt something. those little holes are what let the coolant through. If you do use one you might want to have it welded in a few spots to make it work. sleeves are the way to go..golden eagle are nice..
Old Jan 31, 2004 | 12:58 AM
jDMJeRk's Avatar
Default Re: (GSRT37)
not all of use have an extra 1000 bucks laying around for sleeves! I did a lot of research and talked to a lot of people about boosting on stock sleeves and it is very possible. As long as you tune your motor properly and do everything else right i think you'll be fine with/without one. I bought one cause the machine shop is comfortable with using them. Remember a key to these guards is how they are installed. this isn't a really a dyi type of project. Have a machine shop install it 1/4 inch into the block; weld it in a few spots and you should be good to go.
Old Feb 1, 2004 | 01:51 PM
sPaRk'iT's Avatar
Default Re: (jdmjerk)
ill probably go ahead and buy one and try it out and see how it goes, but thanks for all the reply guys.
Old Feb 1, 2004 | 02:38 PM
lke2drvgsr's Avatar
Default Re: (sPaRk'iT)
as far as making it stronger, ya it should help. but it definitely degrades the engine and creates heat spots.. not good.
Old Feb 2, 2004 | 01:19 PM
sPaRk'iT's Avatar
Default Re: (lke2drvgsr)
hhmmm, really?? that really suck, ill just probably pass on it then, thanks for the info.
a1320addict
May 9, 2005 12:43 AM
matman4444
Jun 12, 2004 09:53 PM
92_civic
Mar 18, 2004 03:34 PM
sPaRk'iT
Jan 30, 2004 10:45 AM
hotintegranights
Nov 16, 2003 10:45 PM
