steering wheel/column problem,need help.
(looking at the pic, #8 and #9, a case that covers the steering column. If I want to remove that, how would I do it, alot of screws/clips? Do I have to remove the steering wheel first? How difficult is it to remove and install back? Cause I don't want to damage the SRS system or anthing around it. People told me that you can just pop the case. true?
I had that off a few years ago, 'cause I had to get to my headlight switch. I don't remember anything difficult about it; couple screws from the bottom (#43) & it comes apart.
All I remember is just unscrew & take them off. You might have to tilt the column down to make room to get the top one off.
I believe all the airbag wiring is in bright yellow harnesses. Don't unplug any of that stuff & you'll be OK.
my car was broken into and they tried stealin the car. they took #8 and 9 off by just takin out the screws. they didnt mess with the steering wheel at all. just move the wheel up and down if you need to.
From: Slut City aka San Diego, Ca, United State Of King
all you have to do is un screw the 2 bolts under the bottom case and then the top case will come off.. no need to take off steering wheel..
ek9tl
Feb 22, 2007 10:34 AM
b18_crx
Jun 19, 2006 09:19 AM
ek_will
Dec 29, 2005 07:45 PM
