steering wheel
I don't know about the search button because I just think it doesn't like me.
Anyways does anyone have a link or a tutorial on taking off the steering wheel. (stock) on a 94 ls.
I think you just take off the star screw but I can't find one in my garage
it is self explanitory. You need a torx screwdriver head. Those hold the Airbag in place. Then you need 19mm to remove the nut that hold the steering wheel in place.
1. Disconnect battery
2. Remove torx bolt from both sides of the steering wheel (you'll need a size 30 torx wrench to do this.
3. Once the screws are removed, you can remove the steering wheel cover, which has the airbag unit attached to it -- there's a big yellow plastic plug that needs to be detached
4. Do you have cruise control? You'll need to cut a hole out in the new steering wheel for it. I had tried just using the old steering wheel backing with the new steering wheel, but the holes didn't seem to line up properly for some reason... You'll now need to transfer the cruise control module to the new steering wheel.
5. Remove the center bolt. At this point, if you don't have a steering wheel puller, it'll make the job a little trickier, but not totally impossible. Go ahead and pull the steering wheel.
6. The rest should be pretty straightforward on mounting the new wheel.
crazyhouse2011
21
Apr 25, 2013 05:58 PM
