starting trouble
Subscribe
Feb 18, 2015 | 12:04 PM
I recently purchased a 97 Acura Integra previous owner made it into a street mod since I've owned it is starting every time till about half hour ago when to go unlock it with my key alarm nothing happened got in turn the key totally dead tried to jump it and it will not charge and it will not start could really use some help asap
Reply 0
Feb 18, 2015 | 12:29 PM
Re: starting trouble
If its totally dead no power at all then check your fuses in the engine bay fuse box, the battery fuse may have blown its the 80 amp fuse.
Reply 0
Feb 18, 2015 | 04:34 PM
if its not recharging, you can also check the fuses under the driver side panel. theres one for the alternator that's around 7.5 amps. its tied in to the speedometer. but that's only if your speedometer doesn't work because theyre tied in together through that fuse.
Reply 0
Subscribe
