starting problems
Old May 17, 2010 | 02:18 PM
untitled23's Avatar
Default starting problems
since ive had this 90 integra it always seems to have a rough start up.takes around 5-10 secs to turn over and start.this morning i went to start it.tried for about 15mins didnt start.then when i got home from school.about 6hrs later it started right up.anyone have any suggestions?
Old May 17, 2010 | 02:24 PM
mouab18c1's Avatar
Default Re: starting problems
Does the motor turn over when it wont start? Is there enough power? check for loose connections to the starter, and ground wires.
Old May 17, 2010 | 03:32 PM
untitled23's Avatar
it does turn over.battery i just got when i got the car 2 months ago.a brand new one.
Old May 17, 2010 | 04:34 PM
untitled23's Avatar
what to check for at the throttle body?
Old May 17, 2010 | 04:49 PM
mouab18c1's Avatar
Starting problems are related with power,fuel and ignition. It could be anything from a fuse to a corroded wire. You just gotta check and test.
Old May 17, 2010 | 04:59 PM
untitled23's Avatar
yeah i think im leaning more towards something with the ignition.theres a passenger side cowl leak that drips down onto the floor at the blower motor.any ignition wires there?at ECU right?
Old May 17, 2010 | 05:09 PM
mouab18c1's Avatar
Yes the ecu is located on the passenger side. The main harness runs behind the dash and wires are almost everywhere. When it doesnt start. Check for spark and fuel.
Old May 17, 2010 | 05:25 PM
untitled23's Avatar
usually doesnt want to start in the morning.better check it early so im not late for school.again,,
Old May 18, 2010 | 04:59 AM
untitled23's Avatar
now i went to start my car and it didnt start.as ive come to conclusion the car wont start in the damp or in the mornings when theres dew on the ground.what could this be from?
Old May 18, 2010 | 05:26 AM
fcm's Avatar
fcm
Old Fart
Can you hear the fuel pump prime?
The PGM-FI Main Relay is a common problem in older Honda/Acura, most common "intermittent" problem is cold solder connections on the circuit board, temp. and humidity can have a great effect on it.
To check for a possible problem with the PGM-FI Main Relay do this, first thing in the morning turn the ign. switch on to run, [not start] and listen for the fuel pump, it should run for a few sec. and then turn off.
If you do not hear the pump...
http://techauto.awardspace.com/mainrelay.html
http://www.tegger.com/hondafaq/mainrelay.html
If you do hear the pump, try and start the engine, let it turn over a few times and if it does not start, immediately remove a spark plug and inspect it, look to see if it is wet with gas and/or smells of gas.
If gas is present, fuel is not the problem.
At the same time you pull the plug inspect the spark plug lead, [part inside the spark plug tube] for moisture also remove distributor cap and inspect for moisture inside the cap.
If all the above is good, [no moisture anywhere] check the connections of the coil and ICM inside the distributor assembly, make sure all these connections are clean and tight, you will need to remove them to check the terminals. 94
Old May 18, 2010 | 06:00 AM
untitled23's Avatar
fuel pump is coming on.i checked the spark plug leads and they all seem good besides one. the 3rd one seemed to have some oil or something in it and all around it as the others dont..as i dont have tools with me i cant pull out the spark plugs.to inspect them
Old May 21, 2010 | 01:34 PM
untitled23's Avatar
i checked everything.and still wont start.now it wont even start up.turns over but just doesnt want to start.any other problems it could be?
gamble01
Apr 24, 2013 06:37 AM
DriveSlowHomie
Jan 22, 2008 10:08 PM
RyanG
Dec 16, 2006 02:17 PM
B18C1 '96 Coupe
Dec 14, 2002 09:50 PM
ZColeon
10
Oct 24, 2001 09:07 AM
