Starting problem, 90 G2
Old Sep 29, 2004 | 03:02 PM
cincispeedemon's Avatar
Default Starting problem, 90 G2
When I got my car it randomly wouldn't start, usually after it had been driven awhile and cooled down. I can turn the key and hear the clicks, but it doesn't try to start, almost like the starter motor isn't getting juice. At first my ecu was throwing the cps code, I fixed that. Brand new battery, rebuilt altenator, and the starter was supposedly replaced before I got the car. I am at the end of my wits with this problem, god someone please help me.
Old Sep 29, 2004 | 03:14 PM
EdoMoto's Avatar
Default Re: Starting problem, 90 G2 (cincispeedemon)
Just get another starter. Its the starter.
Old Sep 29, 2004 | 03:21 PM
purplegsr's Avatar
Default Re: Starting problem, 90 G2 (ITAIntegraLS)
It could be the starter, but have you checked the main fuel relay? That is a common problem in early 90s hondas. The solders go bad and intermittent starting problems start happening more frequently. Can you hear the fuel pump prime? or do you just hear the starter clicking?
Old Sep 29, 2004 | 03:26 PM
..::91TEG-G2::..'s Avatar
Default Re: Starting problem, 90 G2 (purplegsr (Exospeed))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) &raquo;</TD></TR><TR><TD CLASS="quote">It could be the starter, but have you checked the main fuel relay? That is a common problem in early 90s hondas. The solders go bad and intermittent starting problems start happening more frequently. Can you hear the fuel pump prime? or do you just hear the starter clicking?</TD></TR></TABLE>
Old Sep 29, 2004 | 03:40 PM
Default Re: Starting problem, 90 G2 (..::91TEG-G2::..)
I haven't tried that but I will thanks. All I hear is the starter click, I haven't thought to listen for the pump
Old Sep 30, 2004 | 04:43 PM
Where is the main fuel pump relay at?
Old Sep 30, 2004 | 05:55 PM
purplegsr's Avatar
It is located behind the driver side kick panel, behind a metal plate and close to the fuse box. I think there is a little black box (some other relay - blinker maybe?) in front of it.
vietnamezerice
Jan 21, 2009 10:23 PM
pooorman's type-r
Oct 7, 2008 03:07 PM
reomi
Oct 5, 2008 07:14 PM
FSS13foxtrot
Apr 1, 2008 08:05 PM
D3U1LT
Jun 17, 2007 01:05 PM
