starting problem
=- have a starting problem with my 96 integra ls...wella first off the battery ive bought it about 4 months ago.....well last week came home n turn off the engine then turn it on again it would start....but the engine crank over...well i after that happen i decide to charge the battery and but it on...it finally worked but two days ago it did the same thing again..so i decided to push start it n it work.....
what do u guys think....whats wrong with it?
hard to tell, but i think you're saying you have a slow crank, yes?
if you charge the battery or jump start it and it works fine, you have a charging system issue. if so, have a dynamic charging system test performed.
but first, check your connections. make sure battery terminals are tight and clean. and check/clean your trans to chassis ground and your chassis to battery ground connections
Accord15
Feb 21, 2003 09:47 PM
