Starting Issue
Old Aug 24, 2008 | 10:49 AM
Youlose1305's Avatar
Default Starting Issue
So I just recently swapped a ls/vtec motor in my 92 gsr and from a cold start it starts up fine and I have no issues. But the other day I was driving 4 hours to my new place and when I stopped to get gas it wouldn't start so I had a guy push me and just popped the clutch. But the next morning I go out to see if its still dead and it starts right up. Would you guys know what would be causing this starting failure when its hot?
Thanks
Old Aug 24, 2008 | 10:36 PM
Default Re: Starting Issue (Youlose1305)
bump for help
Old Aug 25, 2008 | 05:22 PM
Old Aug 26, 2008 | 12:52 AM
AnDThEnWuT's Avatar
check your main fuel relay, it tends to malfunction during the hot season. Check to see if there are cracks in the soldering, if so, you can easily fix it by resoldering it or just replacing it with one from a junkyard. But your problem can be something different, this is just a suggestion.
Old Aug 27, 2008 | 07:50 PM
Default Re: Starting Issue (AnDThEnWuT)
well its weird that it won't even make a sound or anything but if you push it and pop the clutch then it runs. Thought it would be something in the wiring before something with fuel???
Old Aug 27, 2008 | 08:12 PM
Destructive-'s Avatar
can you hear your starter clicking? it might be your starter going bad~
next time it doesn't want to start, tap the starter with something (that wont break it... ) a couple times and try to start it right afterwards. if it works, the starter is going bad
Old Aug 27, 2008 | 08:14 PM
Default Re: Starting Issue (Destructive-)
no the starter won't even make a sound. All week my car has been starting with no problem. The driving 4 hours just did something
Old Aug 27, 2008 | 08:18 PM
have you tried jumpstarting it? Your battery might be going bad ?
Old Aug 27, 2008 | 08:25 PM
I took it to a Battery Plus place and they said its 2 years and its just fine. But he did add that it was not the EXACT one for my car
Old Aug 28, 2008 | 06:17 PM
more ideas?
Old Aug 30, 2008 | 08:44 AM
Old Aug 30, 2008 | 01:30 PM
i dont really know what to say anymore, you can try getting the one for your car i guess? but..... maybe someone else more experienced can chime in. sorry bro
Old Aug 30, 2008 | 02:37 PM
MrViet's Avatar
maybe the alternator?
Old Aug 30, 2008 | 05:16 PM
Default Re: (MrViet)
so the alt is getting too hot and then not functioning?
Old Aug 31, 2008 | 02:24 PM
MrViet's Avatar
Default Re: (Youlose1305)
dunno i thought someone would jump in and answer.
bump i wanna know too
Old Sep 1, 2008 | 06:01 PM
yeah I'm still wondering???
Old Sep 1, 2008 | 10:12 PM
MrViet's Avatar
bump, anyone?
Old Sep 1, 2008 | 11:37 PM
jonnybadboi9's Avatar
You havent specified this yet, see if everything else is turning on, dash, beeping sound with key in ignition and you hear fuel pump turning on for few seconds.
Then what you should do is keep a bar and hammer in ur car.
If this happens again to you, get that bar and hammer out and put the bar on the starter and hit it not too hard but hard enough like twice.
(Just as DESTRUCTIVE said above)
Then get back in and see if it starts. If it starts back up, then DONT just assume your starter is going bad, cause your starter could be going bad OR one of the wires connected to your starter is lose or corroded where it just snaps on.
So check the GROUND and the other small plug thats connected to your battery that should lead to your starter.
GL & Keep us updated...
Bhoedb8
Feb 2, 2017 07:39 AM
yelnats
Mar 15, 2013 08:35 PM
h224thgensedan
Jul 18, 2007 03:42 PM
RevanDA85
Mar 4, 2007 03:22 PM
g-ride-si
Jan 13, 2006 08:14 AM
