SRS light
Long story short, swapped out my JDM GSR cluster for a USDM GSR cluster. The JDM did not have a plug for the SRS system, so when I plugged in the USDM cluster I plugged in the SRS system. Now I have the SRS light, tried resetting it according to this website
http://boyracersonline.info/videos/h...dicator-light/
but after multiple tries the stupid SRS light will come back on. So im assuming there must be some sort of issue with the system. I have checked all connectors to the SRS system and it's all plugged. Looks like when the Previous owner installed the JDM cluster they just left it unplugged on the cluster. So now im kinda lost, where do I look. Any one dealt with this stupid thing before?
Yes sir I have, I doubled checked because everything else looks fine.
I was also looking at this but kinda got me lost
http://hclar.net/SRS.pdf
Was the steering wheel ever changed?
Have you checked the "short connector" to make sure it was not plugged in to either the steering wheel or front pass. air bag?
Troubleshooting 23-276 is the explanation. 94
I personally never removed the steering wheel. Have not yet checked the short connector also, not sure which one you're referring to. And ill look at the diagram again.
Say what you will to this but mine goes off when i plug in my seat belt. but i also have a 96 spec jdm itr cluster in my 98 usdm gsr so im sure something else is messed up with mine. i hate to say it but try it. it will probably do absolutely nothing but i guess its worth a try.
janvitos
Jun 5, 2008 05:56 AM
JDM 93 EJ1
Oct 14, 2004 12:46 PM
.jacob
Jan 31, 2003 07:35 AM
