squeling
Old Feb 3, 2004 | 10:46 PM
bk11383's Avatar
Default squeling
im in the north, its cold, i have a massive squeal comming from the engine bay, i have a feeling its from one of the belts, which one though? and how do i get rid of it?
Old Feb 3, 2004 | 11:27 PM
LBR92DA-T's Avatar
feel em.. if ones too loose or too tight then do what you have to..
Old Feb 4, 2004 | 04:48 AM
ki3t's Avatar
This user can set his title.
Default Re: squeling (bk11383)
Usually the only two belts I have encountered with is the timing belt and the power steering belt. Might be those two and might not.
Old Feb 4, 2004 | 04:58 AM
Creep's Avatar
Default Re: squeling (Ki3t)
Does it sqeual all the time?
Id put my money on your probably your alt belt. Push on it, it should feel fairly tight.
Old Feb 4, 2004 | 05:36 AM
Jimmy's Avatar
Global Moderator
If you find theyre not to loose...
Find some belt squeeler stuff.
Old Feb 4, 2004 | 05:47 AM
631 Teggy's Avatar
Default Re: (USDMDC2)
Yeah, belts tend to do that in the cold for obvious reasons. How many miles do you have on the belts now?
PS: I only have 35k on mine, and my alternator belt is making noise due to the cold...
Old Feb 4, 2004 | 06:45 AM
dip-set's Avatar
Default Re: (631 Teggy)
my car as doing this also...turned out to be the a/c belt...i just cut it off...it was very hard and dry rotted ..so it will be replaced by the time the summer is back..
Old Feb 4, 2004 | 08:12 AM
TEXN3's Avatar
Default Re: (teg-your-it)
mine do that at startup and till the car is warm. does it go away after a while? does it only squeal at idle and fade away after you hit the accelerator? mine does, i think its the alternator.
plus, it only happens when the car sits outside for a long period of time. i am 99% sure that its just moisture accumulating and it needs a chance to dry, they are slipping a little. my belts are about a year old too. its part of winter driving.
Old Feb 4, 2004 | 09:47 AM
Matty.'s Avatar
alternator belt.
tighten that sucka down!
Old Feb 4, 2004 | 11:25 AM
penney's Avatar
the only prob ive found with that belt squeling stuff is after it wears off it makes your belts squel 10x more, but good temp solution
p.s. teg ur it 's avatar is ****** hilarious
Old Feb 4, 2004 | 11:26 AM
dip-set's Avatar
Default Re: squeling (97vtecGSR)
Old Feb 4, 2004 | 01:39 PM
LBR92DA-T's Avatar
teg-your-it nice avatar.. haha... o/t tho..
Old Feb 4, 2004 | 06:27 PM
bk11383's Avatar
Default Re: squeling (Creep)
only when its cold, it will do it very loudly for about 20 minutes, then die off after the engine is warm
integra15
Sep 13, 2008 01:34 PM
dizzogotvtec
May 13, 2006 01:49 PM
Lamb
Nov 22, 2005 11:44 AM
MeanGreenEG9
Apr 9, 2003 07:38 PM
Ri5e
Aug 14, 2002 11:01 AM
