squeaky suspension
Old Sep 22, 2002 | 08:05 AM
slowacura's Avatar
Default squeaky suspension
my suspension is getting really squeaky and annoying. it's h&r oe's w/ koni reds. how can i get rid of the squeaks?
Old Sep 22, 2002 | 04:22 PM
Deluzional's Avatar
Default Re: squeaky suspension (inteGSR)
You need some new bushings
Old Sep 22, 2002 | 06:50 PM
slowacura's Avatar
Default Re: squeaky suspension (Deluzional)
what are bushings?
Old Sep 23, 2002 | 01:20 PM
gen2tegdriver's Avatar
could just be your hatchback. my car does the same thing since i lowered mine. it's happens because your suspension is stiffer and the chassis flex is a little more harsh. try a rear strut bar.
Old Sep 23, 2002 | 02:24 PM
araknis's Avatar
New User
Default Re: squeaky suspension (gen2tegdriver)
I had the same problem. Took it to 2 places and none could figure it out. The third place I went to just sprayed lubricant all over my shock/spring assembly. That got rid of the squeaking...
Old Sep 23, 2002 | 04:50 PM
DC2_Integra's Avatar
i think it got something to do with the weather. mine squeaks a lot when the weather is cold but other than that its fine.
Old Sep 23, 2002 | 04:53 PM
milanoGSR's Avatar
Default Re: squeaky suspension (DC2_Integra)
same here. i didn't notice it when i first dropped it, but early in the mornings when its cold it'll squeal like a virgin.
Old Sep 23, 2002 | 05:52 PM
MooreBoost's Avatar
Default Re: squeaky suspension (milanoGSR)
Lol milano, mine sqeeked when I had adjustable springs. I ditched em' cause they were saggin like my granma's ****. Now its gone!
gmoore
Old Sep 23, 2002 | 10:26 PM
TimoneX's Avatar
New User
Default Re: squeaky suspension (gmoore379)
Thanx allot for the visual bud.
If you've swapped out any bushings or added camber kits with urethane bushings these may be squeaking. A little white lithium quiets mine down. Try to joust the car and isolate the source of the sound.
Old Sep 23, 2002 | 11:33 PM
Kellindal's Avatar
Default Re: squeaky suspension (TimoneX)
Just about everyone on the board with modified suspension has this problem. There is little you can do. Granted lubing up the bushings is going to stop the squeaking, but it isn't permanent. Once the lubricant wears out, it's gonna squeak again. You can either deal with it, or lube every single bushing every once in a while.
need_a_h22
Jan 15, 2006 06:04 AM
intgrboy
Apr 2, 2004 11:35 PM
Dr. Design
Feb 26, 2004 12:44 PM
