squeaky clutch?
Old May 31, 2002 | 03:56 PM
gsxr's Avatar
Default squeaky clutch?
i did a search, and nothing came up.... it's probably because i dont know what im searching for.
my clutch started to squeak yesterday, after releasing the clutch 3/4 of the way, it squeaks... it didnt make that noise earlier this morning, but it came back in the afternoon... what is the cause of this? are the bushings going? or dry?
Old May 31, 2002 | 04:32 PM
SystemGSR's Avatar
Default Re: squeaky clutch? (gsxr)
ya mine does it too... I'm assuming it's just the weather and the bushings just drying out alittle or somthing. i hope it's not bad
Old May 31, 2002 | 04:55 PM
InTeGrA B18b1's Avatar
were you racing? well it just just be the metal stick thats squeaking its nothing
Old May 31, 2002 | 05:30 PM
gsxr's Avatar
Default Re: squeaky clutch? (LsRTuRBo)
the squeak is audible outside of the car too..... nothing seems wrong with the car, i just get annoyed of little crap like this....
Old May 31, 2002 | 05:36 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
It happens to all integras.. do a search on clutch/squeaky clutch or somthing.. i posted about it like 3 weeks ago.. it should be there.. you can fix it.. I left mine alone.. it comes and goes.. well it did.. till my car got totaled
Old May 31, 2002 | 05:40 PM
ingrate's Avatar
25 Year Member
Default Re: squeaky clutch? (GSR-OwnzJo0)
it's the fork by the slave cylinder. Have someone press the clutch pedal while you listen at the front of the tranny
Old May 31, 2002 | 06:52 PM
legendboy's Avatar
Default Re: squeaky clutch? (In7egrity)
I was wondering about this too!
Old May 31, 2002 | 07:13 PM
gsrvx's Avatar
New User
Default Re: squeaky clutch? (legendboy)
i have this problem too!
-rod
Old May 31, 2002 | 09:06 PM
gsxr's Avatar
is there a remedy? a permenant fix to it?
Thanks
Old May 31, 2002 | 10:00 PM
samagon's Avatar
it may be your throw-out bearing, put your tranny into neutral and release the clutch if you hear a squeeky flutter type sound, this is your TO bearing.
and if you are going in to replace your TO bearing, you might as well change out that clutch too.
Old Jun 1, 2002 | 01:54 AM
ingrate's Avatar
25 Year Member
Thanks
grease up the fork. it's a temporary fix, but it'll do
Old Jun 1, 2002 | 01:55 AM
comptechgsr2000
Guest
Posts: n/a
Old Jun 1, 2002 | 08:22 AM
Big Teggie's Avatar
comptechgsr2000- Why did you post that played out search thing. He stated in his first post that he searched and nothing came up.
Read the original post before you just post that gay thing again. If you dont have anything to say to help the guy out. Then dont just post garbage. I have seen you use that thing for too many posts.
O yeah, Just grease up the fork, and it will sound fine.
Old Jun 1, 2002 | 06:21 PM
gsxr's Avatar
Default Re: squeaky clutch? (Big Teggie)
thanks
is there any particular grease i should be using? can i use the grease that ppl use to grease up their bushings? that green-bluish titanium grease or whatever it is?
Old Jun 1, 2002 | 06:22 PM
Big Teggie's Avatar
Anything high temp will work fine.
JDM_y0!
22
Jun 10, 2012 09:36 AM
thekid03
Mar 20, 2008 01:57 PM
Jmumblez2001
Aug 8, 2006 12:05 PM
efektionz
Feb 15, 2005 02:47 AM
rockwilda
Jun 19, 2002 03:57 PM
