squeaking problem
ok, so i have a 90 teg with a b16a swap and its now squeaking
checked the belts and they are fresh and not loose... only does it when its under load, like wont squeak if im sitting at a light or something, but the faster i go the more it squeaks... i have been told it might be the bearing in the alternator going bad, and if its that then how should i look up the right alternator for it 94-95 eg2 (b16a3 sol)?
and yes i have searched and found nothing that seems like the prob i am having
you might wanna check ur AC belt Tensioner or ur Timing belt Tensioner cause u said it does it when its under load I hope is not ur Timing belt Tensioner.....and on the parts reference for B16a3 look on for 94-97 DOHC Del Sol.....
my old integra, whenever i would start it. it would sqeek from the power steering pump. It wasn't the belt, it was the rotating assembly. Kinda annoying after a while, but i sold it. I would bet if its not belts, its something that rotates with a belt :D (i sound so friggin retarded lol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wangkata »</TD></TR><TR><TD CLASS="quote">you might wanna check ur AC belt Tensioner or ur Timing belt Tensioner cause u said it does it when its under load I hope is not ur Timing belt Tensioner.....and on the parts reference for B16a3 look on for 94-97 DOHC Del Sol.....
thanks ill check that out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb »</TD></TR><TR><TD CLASS="quote">my old integra, whenever i would start it. it would sqeek from the power steering pump. It wasn't the belt, it was the rotating assembly. Kinda annoying after a while, but i sold it. I would bet if its not belts, its something that rotates with a belt :D (i sound so friggin retarded lol)</TD></TR></TABLE>
yea it does not make the sound at start up, only while driving
</TD></TR></TABLE>thanks ill check that out
lankan-balla
Mar 8, 2013 01:02 PM
