Sputtering????
Old Apr 2, 2005 | 09:14 AM
DrewQ1's Avatar
Default Sputtering????
My Teg is acting a lil different. When I roll out of first sometimes it will give a slight jerk or bump like it may cutoff or its not getting enough fuel, but it mainly happens when i'm in 2nd from a roll or in third and i'm just cruising really slow in a prking lot and then if i want pick up speed. It never did that before. If i smash the gas It doesnt really do it. or say i'm at about 40or 45mph and its in 5th and it may do that, and i dont mean that sound when you the car is goin slow and you have it in a higher gear. it just feels like the gas isnt getting there. I filled my car up with that shell v-power gas to see if it may help since i normally put Reg in the LS, Should i add a bottle of those fuel injector cleaners in my tank.
Old Apr 2, 2005 | 12:07 PM
SIK IN DA HED's Avatar
New User
i have the same problem and i still cant figure it out...
Old Apr 3, 2005 | 07:43 PM
DrewQ1's Avatar
Default Re: Sputtering???? (DrewQ1)
anyone else?
Old Apr 3, 2005 | 07:46 PM
efcivic757's Avatar
check timing. My old b16 did it a lot and my timing was off. Check witha timing light and also check by setting the motor to tdc, and check you cams to make sure they are both still set. Might have jumped a tooth on a cam. That fixed it for my old car.
Old Apr 6, 2005 | 05:17 PM
DrewQ1's Avatar
I installed that chevron fule system cleaner, but it still happens. Any other ideas people, or should I try another fuel injector cleaner cause i am just about on E i would do it on my next fill up or should i wait a while before i add another additive in my car since i just put the chevron one in there.
Old Apr 6, 2005 | 07:07 PM
g2tegracer's Avatar
Forget the additives, check the timing like the guy above said. Let us know what the results are.
Old Apr 6, 2005 | 07:12 PM
WhiteGSR95's Avatar
check your timing, and when was your last tune-up
Josh1234
May 8, 2016 02:29 AM
TheHolidayCrew
Sep 9, 2011 11:24 AM
AllMotorHB
39
Sep 24, 2010 12:41 PM
BLU CIVIC
Sep 17, 2007 08:13 PM
Lucky-13
25
Apr 4, 2007 03:36 PM
