which springcompressor from autozone??
Old Mar 13, 2003 | 08:25 AM
1hotintegra's Avatar
Default which springcompressor from autozone??
theres two one that has one peice and another which has two seperate peices?? which one is it?? and im doin camber kit do i need a tie rod or ball joint seperator or can i just use like a screw dirver or something??
Old Mar 13, 2003 | 08:51 AM
IN VTEC's Avatar
Default Re: which springcompressor from autozone?? (1hotintegra)
Strut spring compressor.
You might wanna try a pitman puller for the upper balljoint.
Old Mar 13, 2003 | 09:44 AM
Default Re: which springcompressor from autozone?? (IN VTEC)
ok thats the one with the two parts... waht bout the puller i dont wana buy one they rent one form autozone could i use that one??
Old Mar 13, 2003 | 10:34 AM
Default Re: which spring compressor from autozone?? (1hotintegra)
pleezz guys im doint this tommorow
Old Mar 13, 2003 | 10:39 AM
oldbeefcake's Avatar
Just go there and tell them what car that you plan to use it on. They will know what to rent to you. That's whay I did. They are few different models out there, but they all do the same job.
Old Mar 13, 2003 | 10:54 AM
Aaron M's Avatar
Default Re: which spring compressor from autozone?? (Jun)
goto pep boys
Old Mar 13, 2003 | 11:24 AM
Trac226's Avatar
Default Re: which spring compressor from autozone?? (SilverB18C1)
I rented the strut one from Kragen to do my friend's car. It was worthless cause all it does is hold the orignal spring compressed...so I installed the springs without it, not hard at all.
Old Mar 13, 2003 | 11:29 AM
tC_Dragon's Avatar
did you look at the link i gave you completely????? i have a picture of the pitman/tie rod puller that i rented from autozone to do mine. but additionally, its always good to have a friend helpin ya. It'll make things a little easier.
[Modified by pdcdragon, 12:30 PM 3/13/2003]
oohay32408
Jun 11, 2009 01:01 PM
stealth_EK4
Honda Civic (2001 - 2005)
Mar 17, 2006 08:32 PM
95lstegman
Welding / Fabrication
Jun 6, 2005 03:37 PM
i love rice
13
May 12, 2005 04:41 PM
1EuroEp
Jan 8, 2003 12:54 PM
