Spring removal question
Old Sep 30, 2013 | 06:25 PM
ryanangelo212's Avatar
Icon2 Spring removal question
Found a nice set of aftermarket struts and springs that i'd like to buy, but they don't have the tops of the shock, supposed to use the stock tops.
I've pulled stock shocks apart before to get the tops off, but I fear for my life every time I have to use those spring compressors.
So, was wondering if anyone has ever tried this approach:
I was thinking of leaving the car on the ground, pulling off the 3 strut bolts (14's i believe) and the big middle one (17 or 19 can't remember), then slowly jacking the car up allowing the spring to decompress itself [safely hopefully], then simply tilting it down and pulling the spring and top out.
Would this be safe and effective?
Old Sep 30, 2013 | 09:37 PM
90_EX_Civic's Avatar
Default Re: Spring removal question
that works, and how i do it.
only thing is you have to remember, when you do this, you'll have to contend with the forks on the front, and lca for the rear. as in you won't have room to angle it unless you unbolt some other things.
the way i did the front was to unbolt the upper control arm from the knuckle to get more room. to get more room, unbolt the sway bar.
for the rear, i unbolted the rear upper arm from the trailing arm, and removed the sway bar to get more room
shouldn't take you more then 4hrs if this is your first time. i've gotten it down to 2hrs for fronts and rears.
this is also stating that you don't run into the dreaded lca bolt seizing into the lca. then you have to cut and get ether new bushing, or a new lca.
Old Oct 1, 2013 | 06:42 AM
Johnoolo's Avatar
I personally dented my wheel well doing it that way do not underestimate the power of a released spring
Old Oct 1, 2013 | 07:44 AM
you didn't let the spring release slowly did you?
niceprelude
13
Feb 26, 2009 09:01 AM
BB6-213
Honda Motorcycles
Nov 28, 2008 12:28 PM
.RJ
Feb 19, 2003 04:35 PM
Ignitecivic
Mar 17, 2002 04:37 PM
PatrickGSR94
Feb 15, 2002 12:16 PM
