Spoon throttle body
Old Feb 11, 2003 | 11:21 PM
Got Honda's Avatar
Default Spoon throttle body
Just need some thoughts. I had just finished installing a Spoon sports throttle body on my friends 99 GSR. His current mods are skunk 2 manifold, AEM cold air intake for a type r, dc sports 4-1 header, and apexi n1 catback exhaust. My question is if it is normal to here a whistling noise. I was worried it might be a throttle body leak. Any help is well appreciated.
Old Feb 12, 2003 | 12:04 AM
tC_Dragon's Avatar
Default Re: Spoon throttle body (Got Honda)
well i would double check all of your vaccuum lines, but if your getting a whistle whenthe butterfly/throttle is closed, i would definitely think you have a problem.
Old Feb 12, 2003 | 12:43 AM
B2FiNiTY's Avatar
Is it from his intake?
Old Feb 12, 2003 | 04:02 AM
Fuuma0083's Avatar
Default Re: Spoon throttle body (B2FiNiTY)
If it's after installing the intake your fine, its normal.
Old Feb 12, 2003 | 04:19 AM
Lewie's Avatar
I'm here for the gangbang!
Default Re: Spoon throttle body (Fuuma0083)
What he said
Old Feb 12, 2003 | 11:49 PM
Got Honda's Avatar
Default Re: Spoon throttle body (lewie4)
Well the whistling only occurs during acceleration. But as the rpms get higher the whistling goes away. Any other thoughts? Thanks for all replies so far.
Old Feb 12, 2003 | 11:52 PM
B2FiNiTY's Avatar
Did this happen before when he had the intake? Does it happen at a certain throttle position?
Old Feb 13, 2003 | 12:12 AM
Got Honda's Avatar
It does happen at a certain throttle position. If it happened before? My friend said it did, but i guess i'm just worried because I feel responsible if anything is wrong with it.
Old Feb 13, 2003 | 05:11 AM
RedStarGsr's Avatar
the exact same thing happens with my bored jdm h22 64mm throttle body. I have noticed no defects or reprocutions from this effcet. I installed the TB by itself so i know it is the case, but mine happens around 2-3.5k...how about your friends? I say, just let the car sing!
Old Feb 13, 2003 | 05:29 AM
spoonee's Avatar
Default Re: Spoon throttle body (RedStarGsr)
I think this is normal because I have a 95 GSR with just about the same modifications and it happened to me to...So its nothing to get all worked up about...
Old Feb 13, 2003 | 07:25 AM
bikeboy80's Avatar
Default Re: Spoon throttle body (spoonee)
i think it has to do with the skunk2 manifold, a few people that i know, including myself that after installing the manifold there is a pronounced high pitched wisseling at lower rpms, in might have just been increased with the tb
Old Feb 13, 2003 | 10:25 AM
fEEsh's Avatar
Default Re: Spoon throttle body (bikeboy80)
Contact rockwilda on this board. He has the Spoon throttle body and could help you with this question.
He's also a very good guy and always willing to help someone.
[Edit] Also, AEM intakes had a tendency to whistle.
[Modified by fEEsh, 2:27 PM 2/13/2003]
Old Feb 13, 2003 | 07:33 PM
Got Honda's Avatar
Default Re: Spoon throttle body (fEEsh)
thanks guys for all the help. I guess i'll calm down now. my friend is happy with it so i guess i should too. thanks again for all the help
Old Feb 13, 2003 | 07:51 PM
StinkyTofu's Avatar
I like the whistle
Weel
Mar 9, 2006 08:06 PM
mintscorpion
28
Jun 30, 2005 08:25 PM
Trbospnkr
May 8, 2003 11:18 PM
NeVeR bLoWn
Jan 13, 2003 11:38 PM
EGsex
Dec 10, 2002 03:49 PM
