Speed sensor??
Old Sep 16, 2009 | 12:47 PM
EXLER8's Avatar
Default Speed sensor??
I have a 98 GSR with a turbo, my speed sensor fuse keeps blowing and i dont have a clue why. Can any body help, with idea's or suggestions?
Thanks in advance.
Old Sep 17, 2009 | 12:02 PM
civic91's Avatar
Default Re: Speed sensor??
Thanks in advance.
Do you mind telling me where is the speed sensor fuse located at? Thanks
Old Sep 17, 2009 | 01:09 PM
mouab18c1's Avatar
check for a short somewhere
Old Sep 17, 2009 | 01:35 PM
follie gatts's Avatar
speed sensor fuse is the same fuse under the dash for ELD, alternator, TCM and charging system light. it will blow if you have a bad ground to the negative battery terminal, so i wouldn't assume it's your VSS.
Old Sep 17, 2009 | 03:20 PM
EXLER8's Avatar
I have a battery relocate in the trunk that i will check. What is vss again?
Old Sep 17, 2009 | 03:24 PM
TypeRMOBBiN209's Avatar
vss is the speed sensor
Old Sep 17, 2009 | 03:36 PM
echoside's Avatar
I don't know if it would apply to you or not but there was a tsb for the 99-00 civic si's for that fuse repeatedly blowing because of a wire rubbing under the intake manifold
Old Sep 17, 2009 | 03:52 PM
BradleyJP's Avatar
I'd actually DEFINITLY check that. It's a well known fact that Civics and Integras are basically the same car, and the fact that you're car's a GS-R and the TSB is for an Si, both their respective platform's high-performance models, both with OBD-II DOHC B-Series motors, chances are the engine part of the wiring diagrams will be nearly identical... check around the IM for a short to ground.
Old Sep 18, 2009 | 07:30 PM
EXLER8's Avatar
Thanks guys i will check it all tomorrow.
Old Sep 21, 2009 | 02:28 AM
BradleyJP's Avatar
Any luck?
Old Sep 21, 2009 | 07:25 AM
gs-R_swap's Avatar
where is the speed sensor on a 99 civic si b18c1 swap? do you think that since its a swap its gona be in the original spot an si should have or **** this one of those things they have to convert when doing an engine swap. im having trouble with my car i think i might be getting rid of it soon im tired of dealing with the car problems idle problems.......
Old Sep 21, 2009 | 10:28 AM
mouab18c1's Avatar
its mounted on your tranny LOL
Old Sep 21, 2009 | 10:33 AM
vss is this thing on the left in this pic
here's one in a car
Old Sep 21, 2009 | 09:14 PM
EXLER8's Avatar
No luck yet, everything looks normal.
Old Sep 22, 2009 | 07:04 AM
mouab18c1's Avatar
what do you mean normal? it should be bolted onto the transmission...maybe you should get someone to find it for you...honestly you can see it with your eyes just by looking down at the tranny
Old Sep 22, 2009 | 01:15 PM
EXLER8's Avatar
It is on top of the trans in the back twards the fire wall i located it an looked fine?, nothing rubbing it.
Old Sep 23, 2009 | 07:19 AM
mouab18c1's Avatar
check for bad ground wires
Old Sep 23, 2009 | 03:50 PM
BradleyJP's Avatar
Dude said the TSB talks of the circuit rubbing and grounding out on the intake manifold. Did you follow the harness up to that point to look for issues?
Old Sep 23, 2009 | 06:27 PM
mouab18c1's Avatar
this is funny cause i dont remember any fuse that is labeled for the speed sensor at all!!!
Old Sep 23, 2009 | 07:21 PM
page 23-49 of the dealer service manual
#15 7.5A BLK/YEL Alternator, VSS, ELD unit (USA), TCM, charging system light
Old Sep 25, 2009 | 07:59 AM
210southstar's Avatar
mine wasnt working because it wasnt plugged in my engine harness
Old Sep 25, 2009 | 09:29 AM
mouab18c1's Avatar
good to know..dont have a dealer manual thats why
Old Sep 25, 2009 | 11:07 AM
hondahookup dot com slash manuals
or
if you're a bit torrent person, it's out there
Old Sep 25, 2009 | 12:04 PM
B18C5_VTEC's Avatar
I had this problem on my 98 honda civic. Jack up the car and go underneath and take of the intake manifold support bracket. When you take that off you will see a connector and an open wire. Its really easy and will fix all your problems.
dc2much
Apr 4, 2008 04:43 AM
boostedteg15
Mar 8, 2006 10:19 AM
jshelley45
Dec 18, 2004 11:30 PM
b18c5T
Aug 12, 2001 03:15 PM
