Speed sensor??
I have a 98 GSR with a turbo, my speed sensor fuse keeps blowing and i dont have a clue why. Can any body help, with idea's or suggestions?
Thanks in advance. |
Re: Speed sensor??
Originally Posted by EXLER8
(Post 39986586)
Thanks in advance. Do you mind telling me where is the speed sensor fuse located at? Thanks |
Re: Speed sensor??
check for a short somewhere
Re: Speed sensor??
Originally Posted by civic91
(Post 39997827)
Re: Speed sensor??
I have a battery relocate in the trunk that i will check. What is vss again?
Re: Speed sensor??
(Post 39999925)
Re: Speed sensor??
I don't know if it would apply to you or not but there was a tsb for the 99-00 civic si's for that fuse repeatedly blowing because of a wire rubbing under the intake manifold
Re: Speed sensor??
Originally Posted by echoside
(Post 40000082)
Re: Speed sensor??
Thanks guys i will check it all tomorrow.
Re: Speed sensor??
Any luck?
Re: Speed sensor??
where is the speed sensor on a 99 civic si b18c1 swap? do you think that since its a swap its gona be in the original spot an si should have or tits this one of those things they have to convert when doing an engine swap. im having trouble with my car i think i might be getting rid of it soon im tired of dealing with the car problems idle problems.......:mad:
:mad: |
Re: Speed sensor??
its mounted on your tranny LOL
Re: Speed sensor??
Originally Posted by gs-R_swap
(Post 40031147)
:mad: http://i638.photobucket.com/albums/u...2/DSC01725.jpg here's one in a car http://www.tuner-junction.com/TJForu...4bad_pic_2.jpg |
Re: Speed sensor??
No luck yet, everything looks normal.
Re: Speed sensor??
what do you mean normal? it should be bolted onto the transmission...maybe you should get someone to find it for you...honestly you can see it with your eyes just by looking down at the tranny
Re: Speed sensor??
It is on top of the trans in the back twards the fire wall i located it an looked fine?, nothing rubbing it.
Re: Speed sensor??
check for bad ground wires
Re: Speed sensor??
(Post 40046967)
Re: Speed sensor??
this is funny cause i dont remember any fuse that is labeled for the speed sensor at all!!!
Re: Speed sensor??
Originally Posted by mouab18c1
(Post 40062051)
#15 7.5A BLK/YEL Alternator, VSS, ELD unit (USA), TCM, charging system light |
Re: Speed sensor??
mine wasnt working because it wasnt plugged in my engine harness
Re: Speed sensor??
Originally Posted by follie gatts
(Post 40062702)
page 23-49 of the dealer service manual
Re: Speed sensor??
(Post 40079221)
good to know..dont have a dealer manual thats why
or if you're a bit torrent person, it's out there |
Re: Speed sensor??
I had this problem on my 98 honda civic. Jack up the car and go underneath and take of the intake manifold support bracket. When you take that off you will see a connector and an open wire. Its really easy and will fix all your problems.
