speaker question
Old Apr 11, 2002 | 06:26 PM
94civicx's Avatar
New User
Default speaker question
I know this doesn't belong in this forum but recieved no answer in the audio forum. Do I need to remove the whole door panel on my 96 integra to get to the door speakers or can I just remove the grill
Old Apr 11, 2002 | 06:56 PM
Hoagieryder's Avatar
Default Re: speaker question (94civicx)
hey I took the whole door off , it really is not as hard as it looks just make sure you do not lose all the small screws! Good luck!
Old Apr 11, 2002 | 10:48 PM
dc24me's Avatar
2 or 4 door. Either way, you need to take the whole door off to do a proper install. Besides, it's just like 4 screws anyway.
Old Apr 11, 2002 | 10:51 PM
SYDNEYSIDER's Avatar
Just remove the grill......less time and effort mang
Old Apr 12, 2002 | 05:06 AM
Lou_Cypher's Avatar
take off the whole door and make sure it's done right, that way you don't have to worry about going back......................
Old Apr 12, 2002 | 06:41 AM
bps2799's Avatar
Default Re: speaker question (Lou_Cypher)
Service manual shows only that you need to "gently pry" the grill off (screwdriver covered in tape) to get to and replace the speaker.
I suggest doing it the easy way 1st, then, if you still can't do what you want inside the door, take the door panel off.
Old Apr 12, 2002 | 07:23 AM
Rainmaker's Avatar
Default Re: speaker question (bps2799)
It's like this: If you are replacing the speakers with something of the exact same size, then the grill will be enough. If, however, you want to put in something slightly bigger or deeper, then you'll have to remove and trim the basket, which cannot be accomplished without removing the whole door panel.
Rainamker.
Old Apr 12, 2002 | 07:53 AM
Archidictus's Avatar
Unceasing Measure
Default Re: speaker question (Rainmaker)
takes about five minutes to do either and the doorpanel should come off to do it right and easiest anyhow. just take the panel off.
Old Apr 12, 2002 | 08:32 AM
Fooser's Avatar
Default Re: speaker question (Archidictus)
if the speaker is the same size you should be able to pop the cover off and unscrew it that way. Then carefully slide the new speaker in and tighten it up. As for the Rear speakers you have to take the panels off to get them in. Well your suppost to at least.
Old Apr 12, 2002 | 10:46 AM
94civicx's Avatar
New User
Default Re: speaker question (Fooser)
thank you to all who replied.
Hyard24
Audio / Security / Video
Jan 16, 2008 08:12 AM
Si_Prelude
Dec 12, 2005 06:32 AM
Wildcat1016
Aug 9, 2002 10:38 AM
sicilian2k1
Aug 21, 2001 03:52 AM
Daemione
Aug 8, 2001 12:18 PM
