spark plugs
Old Dec 14, 2001 | 04:20 PM
skunk2 teg's Avatar
New User
Default spark plugs
i wanted to know what type/brand of spark plug everybody uses
Old Dec 14, 2001 | 05:32 PM
da6vtec's Avatar
Default Re: spark plugs (IMPATIENT)
aren't the zfr's for single cams only...the ones to run are the bkr6e-11. if you got a ls you should run the 5's. but if you got a gsr/b16a then you want to run the 6's.
[Modified by da6vtec, 6:33 PM 12/14/2001]
Old Dec 14, 2001 | 05:39 PM
da6vtec's Avatar
you got it mixed up buddy. 5's come stock on the ls motor. so if your running a 5 then it's not a colder plug. 5's burn hotter than 6's. you can get bkr's in 5, 6, and 7 heat ranges.
[Modified by da6vtec, 6:42 PM 12/14/2001]
Old Dec 14, 2001 | 05:47 PM
IMPATIENT's Avatar
Default Re: spark plugs (da6vtec)
yes sir, your right, i had the two mixed up. zfr 6 is recommended thanx da6vtec, for correcting me..........6's are in my car right now..........
Old Dec 15, 2001 | 12:01 PM
Comtechgsr2000s's Avatar
New User
Default Re: spark plugs (skunk2 teg)
I use denso Iridium
Old Dec 15, 2001 | 02:14 PM
Phat Corolla's Avatar
New User
Default Re: spark plugs (Mugenblkgsr2000)
Bosch Laser Platinums...
Old Dec 15, 2001 | 08:56 PM
skunk2 teg's Avatar
New User
thanks mugenblkgsr2000 that was the awnser i was looking for
does anyone use NGK-R plugs?????i just ordered some the guys at acura told me that is what works best got the GS-R which is what i have
Old Dec 15, 2001 | 10:30 PM
Vtec integra's Avatar
denso iridium here
Old Dec 15, 2001 | 11:12 PM
New User
Default Re: spark plugs (Vtec integra)
The NGK are great plugs they just wont last as long as Platnium and Iridium.
Old Dec 16, 2001 | 02:21 AM
kefka's Avatar
sppon plugs here
Old Dec 16, 2001 | 11:21 AM
IMPATIENT's Avatar
Default Re: spark plugs (madeinjapan)
i've been told that the platinum plugs were junk and to stick with the regular ngk, but i don't use them so i can't really voice that.........
Old Dec 16, 2001 | 11:29 AM
IN VTEC's Avatar
bkr6e-11 in b18c1
Old Dec 16, 2001 | 12:07 PM
spoon?
they make spark plugs?
Old Dec 16, 2001 | 07:04 PM
wickedxbo1's Avatar
New User
Those damm spoon plugs are expensive............around 100-150 for all 4
Old Dec 16, 2001 | 10:20 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: spark plugs (wickedxbo1)
Bocsh 4227 $1.99 each, replace every year or more often.
Old Dec 16, 2001 | 10:43 PM
X2BOARD's Avatar
Default Re: spark plugs (Mista Bone)
NGK BP6es
or
ZFR6F11 (I think that's the code)
Old Dec 17, 2001 | 08:30 AM
dynamite C1's Avatar
Default Re: spark plugs (IN VTEC)
PFR6G-13 OEM NGK Laser Platinum
Old Dec 17, 2001 | 09:41 AM
exquivical's Avatar
New User
Don't get platinums. Platinum's are made for long-life, not better spark - Basically, they aren't as good as a conducter than copper.
Old Dec 17, 2001 | 11:23 AM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: spark plugs (dynamite C1)
how much are those NGK plugs?
Old Dec 17, 2001 | 04:14 PM
ingrate's Avatar
25 Year Member
Default Re: spark plugs (FuknGSR)
ngk platinums are awful expensive.. like $15 a pop! i got a set of 4 BKR6E-11's for $6.xx at pepboys the other day
Old Dec 18, 2001 | 08:40 AM
SuperMan19's Avatar
New User
Default Re: spark plugs (In7egrity)
I use NGK Iridium plugs.
Old Dec 18, 2001 | 03:18 PM
skunk2 teg's Avatar
New User
Default Re: spark plugs (MyKarsNameIsMichelle)
how much are the ngk iridium plugs?
Old Dec 18, 2001 | 03:58 PM
SuperMan19's Avatar
New User
I got it off of ebay for umm if I can remember.. $38.. but check eBay out yourself.. They might be more/less now?? I dunno.
Old Dec 19, 2001 | 05:47 AM
exquivical's Avatar
New User
Common misconception with, well, just about everything is that the more it costs the better it is. Any quality copper based plug is going to be fine unless you have a friggin' 600hp beast. Just go get some good bosch or ngk standard copper based plug. Don't let the hype get to you with all these different plugs.
Old Dec 19, 2001 | 08:46 AM
maggsgsr's Avatar
Default Re: spark plugs (exquivical)
I've been told the platinum plugs make the car more efficient and are made to last longer,the regular NGK's are a better conductor and make the car run slightly better but won't las as long.My advice go to NGK,i switched back to platinum and the car felt a little sluggish,i can't say for sure but in my ipionion i believe the platinums are crap unless your looking for a plug that will last a long time.
