Spark plug reading
Old Nov 15, 2013 | 11:48 PM
BIGef's Avatar
Default Spark plug reading
Anyone know if I'm running lean or not? Or it's normal.
The tip looks greenish or something
This is a stock b18b1 with intake exhaust and headers.
Also got wideband installed afr at idle 13.9-14.9
Cruising 13-14s
WOT 13.0-13.4
Old Nov 16, 2013 | 07:42 AM
B_Swapped93's Avatar
Default Re: Spark plug reading
looks normal to me some oil build up at the thread base but the actual tip looks fine.
Old Nov 16, 2013 | 03:27 PM
fcm's Avatar
fcm
Old Fart
X2, plug looks OK, but you need a new V/C gasket set, the spark plug tube Orings are shot. 94
Old Nov 16, 2013 | 07:02 PM
Blackhalo6's Avatar
x3 the greenish yellow tint comes from sulfur they use in fuel additives.
Old Nov 16, 2013 | 07:07 PM
DDTECH's Avatar
You want a solid, black fuel ring, which you have, your fueling is good, your timing mark looks good too, typically you want your timing mark, around the 90 degree bend..which yours is.. you can see the color change, from the front of the tip to the bottom, the darker grayish part is your timing mark.
Old Nov 17, 2013 | 04:11 PM
BIGef's Avatar
Thanks ddtech for the good info, what I needed and also for the rest of you guys.
Feeling confident I street tuned this myself. Took awhile to do though.
Old Dec 18, 2013 | 09:08 PM
Mista Bone's Avatar
D Tranny Guru
How can you see the fuel ring from all the oil on the plug? Besides the plug would need cut apart to see the fuel ring at the base.
OP: You are running lean, hope you don't melt anything.
Old Dec 20, 2013 | 06:38 AM
Eg.ls.turbo's Avatar
Good info. I like to learn a lil more on spark plug reading.
foodkeeper
Engine Management and Tuning
12
Jul 8, 2017 03:16 PM
crashsvg
Oct 14, 2011 09:26 AM
Tad
Apr 11, 2005 01:40 AM
Tad
21
Oct 29, 2003 12:28 AM
TurbodCX
Apr 23, 2003 04:45 AM
