SPARK PLUG HELP!
Old Dec 23, 2011 | 09:46 AM
bvillarreal's Avatar
Icon2 SPARK PLUG HELP!
What would be the best plugs for fully built ls/vtec boosted? Car is on 11 psi if that makes a difference.......
Also, is it bad to go from full synthetic to synthetic blen oil??
Old Dec 23, 2011 | 10:22 AM
DirtyDA9's Avatar
Default Re: SPARK PLUG HELP!
Full synthetic and synthetic are the same thing. Some brands just say "Full". And you want to use a colder degree plug.
Old Dec 23, 2011 | 10:53 AM
B20ztek's Avatar
Ngk BKR5E is the one you need i believe
Old Dec 23, 2011 | 11:11 AM
Are 8s colder than 11s? and i mean switching from full synthetic to conventional 10 30
Old Dec 23, 2011 | 12:03 PM
DirtyDA9's Avatar
It isn't advised that you switch from conventional to synthetic and visa versa.
Check out this page for numbers/heat range
http://www.ngk.com/glossary.asp?kw=H...g?&manID=1&pt=
Old Dec 23, 2011 | 12:26 PM
sebTeggy's Avatar
Why do people cheap out on oil? Run synthetic, always. This isn't a tercel man
Old Dec 23, 2011 | 01:17 PM
TheRealTegger's Avatar
Way, way back, before any of you were born, synthetic oils developed a reputation for drying-out seals. This reputation is no longer valid, if it ever was.
Nowadays, you can safely use whichever oil you want--mineral or synthetic or a blend--so long as it meets the automaker's specifications. And you can safely swap between one type and the other as you wish.
I will say, though, I am mightily impressed with how sparkly-clean synthetic (Mobil 1) keeps my engine, and I have no plans to switch back.
Old Dec 23, 2011 | 02:16 PM
DirtyDA9's Avatar
^^ that rumor is probably true of running conventional for a long time then switching to synthetic
Old Dec 24, 2011 | 05:46 AM
I stayed with synthetic lol
Old Dec 25, 2011 | 12:36 AM
Wrona's Avatar
its boosted on 11 psi... wow means nothing
808k20a2
May 17, 2011 01:26 AM
CRZ1
Apr 26, 2009 08:59 PM
SinsEvil666
10
Jun 4, 2008 12:04 PM
mongoliandonuts
Aug 27, 2004 11:51 PM
sa21199
Jan 5, 2002 08:07 PM
