SOMEONE HELP!!!!
Old Aug 24, 2007 | 12:50 PM
Gsr94black's Avatar
Default SOMEONE HELP!!!!
Ok, I have a '90 LS Auto and I have been having some weird issues. The car does some weird hesitation/stuttering crap. I can be at a dead stop, put my foot on the gas lightly, and the car goes then feels like it is bogging down then goes then bogs then I put it to the floor and it takes off like it should. It does this when I hit turns and try to accelerate too. I can be going into a turn and hit the gas and it feels like it is going to drop on its face. Can also do it when going up a hill...Ill put my foot on the gas to keep a constant speed and the rpm's surge about 300-500 rpms every couple seconds. And one last thing, I went around a corner hit the gas, it bogged then back fired...WTF!?!?!?!?!
Now what has been done. I have changed the plugs, wires, cap, rotor, fuel filter, fuel pressure regulator, injectors are good, and intake filter is good. I was told it couple be a sensor or an anti-freeze issue???????
PLEASE SOME HELP!!! I have dropped so much money into this thing playing the guessing game.
Old Aug 24, 2007 | 01:48 PM
SoTexDC2's Avatar
Default Re: SOMEONE HELP!!!! (Gsr94black)
Are you throwing any CEL's?
Old Aug 27, 2007 | 10:26 AM
Gsr94black's Avatar
Default Re: SOMEONE HELP!!!! (SoTexDC2)
No lights at all
Come on guys....I know there are people on here that can help me...anyone?
Old Aug 29, 2007 | 07:15 AM
Gsr94black's Avatar
Update: HERE IS A VID
This is taken in nuetral with my foot steady on the gas....you can clearly see the rpm surge.....what is the issue?
http://s82.photobucket.com/alb...5.flv
Old Aug 29, 2007 | 07:23 AM
r1ch1e's Avatar
how's your rotor and cap? what about your 02. throttle sensor?
Old Aug 29, 2007 | 07:59 AM
Gsr94black's Avatar
Default Re: SOMEONE HELP!!!! (r1ch1e)
The cap and rotor are new and I haven't meesed with the 02.
Old Aug 29, 2007 | 08:09 AM
Mfoehrkolb's Avatar
try a full tune-up and some injection cleaner. When you backfire, it cause the sparkplug, blows out. ex. too much fuel, distributer/spark probelms etc.
Old Aug 29, 2007 | 09:16 AM
Gsr94black's Avatar
Default Re: (Mfoehrkolb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb &raquo;</TD></TR><TR><TD CLASS="quote">try a full tune-up and some injection cleaner. When you backfire, it cause the sparkplug, blows out. ex. too much fuel, distributer/spark probelms etc.</TD></TR></TABLE>
Well have have done all that....I have replaced everything tune up wise and have tried injector cleaner.....im at a dead end and I dont know what else to try
Old Aug 29, 2007 | 09:29 AM
Mfoehrkolb's Avatar
maybe a MAP sensor.
Old Aug 29, 2007 | 09:55 AM
dc2415's Avatar
maybe it's a tps sensor? or maybe you have timing issues?
Old Aug 29, 2007 | 10:00 AM
Gsr94black's Avatar
Default Re: (dc2415)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2415 &raquo;</TD></TR><TR><TD CLASS="quote">maybe it's a tps sensor? or maybe you have timing issues?</TD></TR></TABLE>
I have checked and rechecked the timing, so that is good. Is there any test to do to see if it is a sensor instead of buying new ones?
Old Aug 30, 2007 | 08:48 AM
Gsr94black's Avatar
Default Re: (Gsr94black)
How do I see if the sensors are bad?
Old Aug 30, 2007 | 12:41 PM
dc2415's Avatar
i think if your sensors are shot to ****, then it will throw a cel. however, if it's not and it's just dirty but not totally gone it will cause your car to run funny. i think team-integra has a link to how to clean certain sensors might want to check that out
Old Aug 30, 2007 | 03:33 PM
Gsr94black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2415 &raquo;</TD></TR><TR><TD CLASS="quote">i think if your sensors are shot to ****, then it will throw a cel. however, if it's not and it's just dirty but not totally gone it will cause your car to run funny. i think team-integra has a link to how to clean certain sensors might want to check that out</TD></TR></TABLE>
I posted the same thread over there but I haven't gotten any responses yet
Old Aug 30, 2007 | 04:08 PM
1Point8DC2's Avatar
to check your sensors you'll need amulti meter. to check map sensor there are three wires
yel/red
grn/wht
red/grn
with key on engine off you should have 5 volt reference between yel/red wire and grn/wht
between red/grn and grn/wht you should have something like 2.5 2.8volts
with engine running or with vacuum pump attached apply vacuum and check voltage again between red/grn and grn/wht as vacuum increases voltage decreases. i really don't think this is your problem b/c you usually throw a cel.
same setup with tps sensor but i don't know the wire colors for that. hope this helps
Old Aug 30, 2007 | 04:23 PM
XSIintegra's Avatar
Default Re: (1Point8DC2)
Either your MAP or TPS sensor are shot or you've got an air leak behind the throttle body... ie. the manifold gasket.
Do the RPMs loop at idle?
I had my '92 LS drive really bad one afternoon. Luckily I had a Apexi VAFC hooked up and switched to the voltages screen, to find my TPS going all over the place in voltage.
Replaced it and it has run great since...well, before I blew the engine up
Old Aug 31, 2007 | 07:34 AM
Gsr94black's Avatar
Default Re: (XSIintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSIintegra &raquo;</TD></TR><TR><TD CLASS="quote">Either your MAP or TPS sensor are shot or you've got an air leak behind the throttle body... ie. the manifold gasket.
Replaced it and it has run great since...well, before I blew the engine up </TD></TR></TABLE>
No loop at idle. I had that but I cleaned the IACV and it went back to normal.
Old Sep 4, 2007 | 08:55 AM
Gsr94black's Avatar
Still no fix............
Old Sep 4, 2007 | 09:43 AM
95 integra's Avatar
TPS or MAP sound like a good place to start. Did you replace/mess with anything right before it happened (this includes ANYTHING, even if you dont think it caused the problem). It does sounds like its getting too much fuel which would be the MAP or TPS. It could also be an ecu issue, however thats unlikely unless you just installed an afc or chip. Is the vacuum line going to the MAP broken? Try replacing that as well.
Old Sep 4, 2007 | 11:49 AM
Gsr94black's Avatar
Default Re: SOMEONE HELP!!!! (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">TPS or MAP sound like a good place to start. Did you replace/mess with anything right before it happened (this includes ANYTHING, even if you dont think it caused the problem). It does sounds like its getting too much fuel which would be the MAP or TPS. It could also be an ecu issue, however thats unlikely unless you just installed an afc or chip. Is the vacuum line going to the MAP broken? Try replacing that as well.</TD></TR></TABLE>
I had two things that I messed with prior to it happening.
1.) I had a small leak in a hose leading to my IACV and I replaced that hose with one that was to long so it was kinked. I put the right length in and no more idle searching.
2.) I had an injector leak which was bad enough to smell inside the car at all time and I replaced that.
After I did those two things I noticed the surging issue which is slowly getting worse.
Oh yeah, and the exhaust is messed up but I was told that that isnt an issue. I accidentally hill jumped the car...lol...and the pipe broke the welds coming out of the muffler to where the exhuast tips were dragging. When the welds broke it actually broke the pipe free inside the actual muffler so it would swing up and down freely but unable to fall off....a little coat hanger action fixed that. All of that was prior to the anti freeze leak fix and the injector fix.
Old Sep 5, 2007 | 12:27 PM
Gsr94black's Avatar
This crap keeps gettin worse
Old Sep 24, 2007 | 01:36 PM
93AcuraIntegraGSR's Avatar
hey did you end up figuring out what was wrong with your 90ls?
Oreo-TeCk
Sep 28, 2006 09:30 AM
projsectEF
Sep 10, 2006 06:58 PM
W.O.P.
Jan 6, 2005 01:46 PM
TeGGY_LS
Feb 8, 2004 09:14 PM
