some help needed here.
cel code 8 TDC. is that the distributor,
if so would buying an entire assembly from scrap yard bring back the power n throw out the code n fix the bogging/powerless bs my integra is feeling? ;o.
ialso cannot get a full alignment due to the rear being seized?, company said id need to replace shocks lcas and control arms , is this tru?
also my headlights are apparently brand new but when i try adjusting them via the wheel with a screw driving nothing happens, they just keep turning., ? how do i fix that .
also i need to replace headgasket, whats the best to order for a 95 integra rs, oem or aftermarket? also wheres a good place to order parts .
https://honda-tech.com/zerothread?id=2138681 here. judging by what was in there check your distributor and make sure that all the wires and plugs are secure. if that doesn't help, you should try another distributor.
JBirch_97Prelude
Jun 25, 2006 12:31 PM
