Some ? about jdm conversion
Old Dec 26, 2006 | 12:35 PM
DjMigs's Avatar
Default Some ? about jdm conversion
1. I was told you need jdm fender brackets is this true?
2. Do I need to replace my USDM gsr Fender Liner to a jdm itr?
by the way where you fellas pick them up from?
3. Can i use my jdm cable latch & if it doesnt work what car are you using them off of...
4. i understand i need to use a longer cable for the hood used from da?
5. Is a Bumper extension really need?
tia
Old Dec 26, 2006 | 12:46 PM
Kyoto now's Avatar
Default Re: Some ? about jdm conversion (DjMigs)
I've been curious about this topic as well, It's something I'm considering doing. I heard there's welding involved, is this correct? Is converting the front end to a JDM one something that I could do or should I have a body shop that's done this before do it?
Old Dec 26, 2006 | 01:03 PM
kiddcarbuff's Avatar
you DONT ned the fender liners, yes you need fender brakcets, bumper support bumperbracket bump, grill, hood and the rad support which is welded in, try to get new fenders and a new rad support, it will save headaches when it comes time to insstall and paint, and u can use the stock hood cable and latch
Old Dec 26, 2006 | 01:10 PM
ir0nmanx's Avatar
Default Re: (kiddcarbuff)
your stock hoodlatch cable is too short, you will need a 90-93 integra cable.
Old Dec 26, 2006 | 01:28 PM
kuja's Avatar
No, u don't NEED the fender brackets. U can bend the ones already there just fine.
Again, u don't NEED fender liners, but if u want them, u will need to pay 150$ for the JDM ones.
(passwordjdm.com)
The jdm latch is what you use.
DA cable, no stock one is too short.
Yes
da9:: It's not hard, but its not a walk in the park either. If I were to do it again i'd save myself the trouble and have a shop do it.
Old Dec 26, 2006 | 10:00 PM
JDMilanoRed's Avatar
Default Re: (kuja)
you dont necessarily NEED the fender brackets, but the will keep your fenders from sagging... you can easily fabricate something to compensate for this or bend the JDM fenders slightly if/when they start to sag
the US/JDM hood latch is too short... get a DA (90-93 integra) cable from acura/junkyard.
you dont NEED the fender liners...you can cut your existing US ones
I would recommend having both the bumper support as well as the extension
Old Dec 27, 2006 | 07:05 AM
hmhm i managed to use the stock cable.... weird
Old Dec 27, 2006 | 10:08 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff &raquo;</TD></TR><TR><TD CLASS="quote">hmhm i managed to use the stock cable.... weird</TD></TR></TABLE>
I did too, but I dont recommend it.
Use the DA cable.
Old Dec 27, 2006 | 03:44 PM
ir0nmanx's Avatar
Default Re: (CARMA_626)
is it hard to install it?
Old Dec 28, 2006 | 06:27 AM
InfiniteMotors's Avatar
I'm about to do this at the same time as a RHD using a clip, I'll post how the cables and brackets turn out
Garrett
Oct 28, 2016 10:05 AM
silentdeath12886
Jun 20, 2006 05:13 AM
redline32
May 30, 2004 02:46 PM
98itR484
Feb 23, 2004 07:10 PM
DC2_Integra
Jun 6, 2002 02:54 AM
