SMOG help/advice
Old Aug 31, 2004 | 01:48 PM
debogsr's Avatar
Default SMOG help/advice
Can anybody help me with this? These things are kinda hard for me to read, and i was wondering if anybody had any advice on anything i could do to help it pass the things it didnt or reccomend a shop in the Bay Area that would help.
First thing is that i didnt know if the Check Engine light was on that it would fail automatically. I wouldnt of even take it in. Either way, the guy didnt tell me so he charged me after he tested it. The light turned on when i switched my stock 95 gsr exhaust for my friends 99 gsr exhaust. Mine had a rattle i wanted to solve so i switched the two. It solved the rattle, but the light came on.
All i have is a AEM CAI and DC 4-2-1 Header which i didnt think would do anything
The gas cap i guess isnt holding the right pressure or what not so i guess i can buy a new one.
The emissions is what im really having questions about.
Thanks everyone for reading.
Old Aug 31, 2004 | 02:16 PM
blacknbean's Avatar
Default Re: SMOG help/advice (debogsr)
i would first check what code the CEL is throwing and fix that. if that doesnt help acura has a 80k emissions warrenty..if ur under warrenty, take it to them...your cat might be bad
Old Aug 31, 2004 | 02:21 PM
debogsr's Avatar
Default Re: SMOG help/advice (blacknbean)
not under 80k, Im at about 125k to be exact. I dont know if this would help anyone but i just changed the spark plugs and wires with OEM Honda Stuff. I havnt messed with the distributer yet though
Old Aug 31, 2004 | 02:45 PM
TunerN00b's Avatar
High HC and CO are, as far as I know, a sign of a bad catalytic.
Old Aug 31, 2004 | 02:48 PM
debogsr's Avatar
Default Re: SMOG help/advice (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">High HC and CO are, as far as I know, a sign of a bad catalytic.</TD></TR></TABLE>
Hey thanks alot man, well i just checked the code on my CEL and its code # 41 Primary oxygen sensor heater. Can anybody put this into english for me and tell me whats wrong???? Thanks alot for the help guys
Old Aug 31, 2004 | 04:02 PM
debogsr's Avatar
Heres a picture of the obd1 connecting to my cat. Notice the white wire is disconnected. Could that be the code #41???????? Should i connect it back up? Thanks
Old Aug 31, 2004 | 05:36 PM
debogsr's Avatar
ttt
Old Aug 31, 2004 | 06:55 PM
gen2moredoors's Avatar
is that a 4 wire o2 sensor? if so i believe it doesn't matter what obd, it needs all four wires, except for obd0 which is a 2 wire sensor..hook that up and that should fix it!!!
Old Aug 31, 2004 | 07:50 PM
ME=ADRIAN's Avatar
Default Re: (NTeg2rafied)
if connecting those wires back up doesn't work then just get a carsound high flow cat. it should help you pass smog and is a lot (I MEAN ALOT) cheaper than an oem cat and it flows better
Old Aug 31, 2004 | 08:33 PM
debogsr's Avatar
Default Re: (pacoimero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pacoimero &raquo;</TD></TR><TR><TD CLASS="quote">if connecting those wires back up doesn't work then just get a carsound high flow cat. it should help you pass smog and is a lot (I MEAN ALOT) cheaper than an oem cat and it flows better</TD></TR></TABLE>
Thanks alot, that might be what i do. But for some reason, the CEL light went off after i was playing with it for a bit. I dont no if i fixed it or just reset it.
Old Aug 31, 2004 | 10:32 PM
debogsr's Avatar
Default Re: (debogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">
But for some reason, the CEL light went off after i was playing with it for a bit. I dont no if i fixed it or just reset it. </TD></TR></TABLE>
first time i ever quoted myself, lol, anyways the CEL light just came back on. I dont really know whats going on and im getting tired of this. I havnt had time to check the code this time but im assuming its 41 again.
mreed
Nov 29, 2010 09:44 PM
civicSF98
Jan 16, 2010 04:15 PM
LINKIN024
Oct 13, 2006 05:14 PM
red_ek_hatch
Mar 21, 2005 05:57 PM
