SMOG Help
Old Jan 19, 2005 | 10:23 PM
shorto85's Avatar
Default SMOG Help
Ok guys I am having trouble passing smog. I am having trouble passing the 15 MPH test... the 25 MPH test I pass just fine. Here are the readings I am getting:
15 MPH Test
HC (PPM): Max (90) MEAS (139)
CO (%): Max (.54) MEAS (.59)
NO (PPM): Max (711) MEAS (949)
25 MPH Test
HC (PPM): Max (56) MEAS (56)
CO (%): Max (.53) MEAS (.18)
NO (PPM): Max (754) MEAS (38)
I have a CAI and dc 4-1 headers. That test was with the CAI on. The cat was just replaced last year along with a brand new O2 sensor. Can anyone make any suggestions? Tonight I replaced the cap, wires, plugs, and also put the stock air intake back on. On the stock airbox I dont have the little hose that connects from the valve cover to the intake itself. The only hose I have is one for my aftermarket intake.
Old Jan 19, 2005 | 10:27 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: SMOG Help (shorto85)
Try to find someone so you can borrow that hose to connect it back. It's gotta be connected, else you may fail visual inspection.
And after all is said and done, you should pass with flying colors.
ONE ADVICE you must HEED TO:
Before you go the to the smog place, beat the **** out of your car to heat up the CAT really well. And after you arrive there, don't turn the car off.
88LXiProject
Oct 20, 2003 09:56 PM
88LXiProject
Oct 2, 2003 10:40 AM
Brian-Brian
Apr 29, 2003 11:22 AM
Racerage1
Jan 31, 2003 07:33 PM
