Smog
Old Dec 29, 2005 | 05:14 PM
pelon1987's Avatar
Default Smog
well I just got back from smogging my car and it didnt pass!!, Anyways, i had just finished rebuilding the motor and i expected it to pass but i didnt change the plugs and plug wires, the man at the smog station said it wasnt anything big, just that the emissions is just above not passing, but he said that my catalyc converter may be bad because the reason i rebuilt my motor was because a valve broke, so now i have to figure out what can be wrong, any recommandations about my problem will be appreciated.
Thanks,
Pelon1987
Old Dec 29, 2005 | 05:17 PM
WhoDoYouThink's Avatar
Default Re: Smog (pelon1987)
damn bro i feel so bad for you CA guys going thru that smogging bullshit. that is such **** that you have to do that man. good luck
Old Dec 29, 2005 | 05:26 PM
pelon1987's Avatar
Default Re: Smog (2000turbogsr)
yeah I know, but I mean the motor is like brand new except for the small things, so tomorrow I will start to replace all the small things, besides I'm mexican, I can easily get around "things" but thats not the point for me because I still want to find out why my car didnt pass
Old Dec 29, 2005 | 05:41 PM
lol, either way good luck with it bro.
Old Dec 30, 2005 | 12:21 PM
TEST ONLY's Avatar
Pelon, hope you figure out why your ride doesn't pass. Try running some seafoam through it, then make sure you run it hard for a couple hundred miles before you go and smog it. Sounds like you haven't burned all the oil out of the catalytic just yet. Run it hard and you should be Okay.
Old Dec 31, 2005 | 01:08 PM
DC4me's Avatar
if you barely failed just change your spark plugs, wires, do an oil change, and probably replace your catalytic converter... that should do it since your motor is rebuilt.. also just leave your car running once you get to the smog station..
Old Dec 31, 2005 | 01:34 PM
Aloha04MSM's Avatar
post up your numbers that way we can see where you failed and by how much. If i can see the numbers you put down plus what the average and max allowable for your car is, i can tell you what is causing the problem.
Old Dec 31, 2005 | 02:47 PM
viet_boi_racin's Avatar
Default Re: (b18cinteg96)
make sure you run the car hard for about 30 min before you go in to test.. If you barely failed then try putting a bottle of alcohol in with 1/2 a tank of gas and run it for 1/2 an hour then go in and test. My buddy's car failled soo bad in like 3 different catagory, then we put alcohol in there, it passed every catagory except one.. then we went down and took out his cat and realize it was hollowed out. lol.. so if you're barely failing that should get you through it.
Old Dec 31, 2005 | 03:23 PM
pelon1987's Avatar
Default Re: (viet_boi_racin)
what do you mean by alcohol, what kind and ill try to post pics of the results as soon as possible.
Thanks for the info.
Pelon1987
Old Dec 31, 2005 | 05:56 PM
Racermech's Avatar
Default Re: (pelon1987)
There is no need to run seafoam in a new engine.
Post up the numbers, A lot of guys have failed and then figured out what was wrong, Do a search and see what you come up with.
Old Dec 31, 2005 | 10:02 PM
Default Re: (Racermech)
alcohol as in rubbing alcohol... you can buy it at the phamacy or what ever for like $1.49 something like that....
Old Dec 31, 2005 | 10:29 PM
ErMaK's Avatar
I cant even start to imagine how much hell is must be for yall California guys to have to put up with that smog stuff. I guess I'm lucky that my state doesnt have emission laws(yet). Good luck with your tests.
Old Jan 1, 2006 | 06:45 PM
pelon1987's Avatar
Here are my numbers.
Old Jan 1, 2006 | 06:50 PM
pelon1987's Avatar
so here are the numbers of the smog, hopefully it helps.
Thanks for any input
Old Jan 3, 2006 | 11:49 AM
TEST ONLY's Avatar
You're almost there Pelon. Have you double-checked that the EGR, vacuum hoses and ECU are working properly?
Old Jan 3, 2006 | 12:20 PM
pelon1987's Avatar
no I havent done that, but my permit to get it smogged ended today, and i had to get the car to "pass" by other measures, but i'm still gonna replace those things because I know that it is something real minor or just bring my car up to good performance again.
Anyways thanks for the comments, keep them coming.
Pelon1987
Old Jan 3, 2006 | 07:45 PM
i'm telling you.. you're not failing by too far. Toss a bottle of alcohol in with 1/2 a tank of gas... run it for 1/2 an hour and go in and test.
Old Jan 3, 2006 | 07:59 PM
Gant's Avatar
im a smog tech put a new cat on, done deal. seafoam ur engine? the point of that is to clean out all the carbon build up in ur engine, if your car failed for NOX i would do that, but ur fine in nox,
oh and check ur egr? once again thats only if u had a nox fail
its pretty funny how ppl give false advice eveywhere, change this change that.
you barely failed on HC , hc is hydro carbons, hc is unburnt fuel, ur cat is not doing its job at low speed, but when you hit the 25mph test you pass ur cat is the problem garunteed.
if u had a fucked up valve then that would def kill a cat.
nox is what MOST hondas fail for, nox is cuased of combustion temps reaching over 2500 degrees, combustion temps! not engine temps.
what happens at 2500 degreres? nitrogen and oxygen get married and have a baby called NOX, nox is what is part of photochemical smog(the smog we can SEE with our eyes)
so what can cuase high nox? carbon build up in a engine artifically raise's compression..what happens when u raise compression? you get more heat, more heat more chance of nox.
egr malfunction
cat malfunction
to far of ADVANCED timing
overheating
fan not coming on.
goes on and on.
all your readings are good, and just shows ur cat is worn and tired. please dont replace plugs and wires, all u need is a new cat.
Old Jan 4, 2006 | 02:06 PM
xx89civicracer89xx's Avatar
Default Re: (Ba4)
Hey Ba4 i also just got back from smog 10 min. ago and my car faild NOx.. only on the 15mph one tho... MAX=835 AVE=237 MEAS=894 what do u think i should do? at the 25 mph one it passed at MAX=774 AVE=199 AND MEAS=764.... thanks let me know asap cuz i need to get the car smoged and reg...
Old Jan 5, 2006 | 01:44 PM
TEST ONLY's Avatar
Pelon, all you need is a new catalytic. Run the car for 20-30 minutes, make sure are your vacuum lines are connected and add some fresh fuel to the tank. You're almost there, a new catalytic will pass you ASAP.
Old Jan 7, 2006 | 07:30 PM
TEST ONLY's Avatar
Pelon, email me and I can get you another permit ASAP.
Old Jan 7, 2006 | 07:58 PM
Gant's Avatar
Default Re: (xx89civicracer89xx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xx89civicracer89xx &raquo;</TD></TR><TR><TD CLASS="quote">Hey Ba4 i also just got back from smog 10 min. ago and my car faild NOx.. only on the 15mph one tho... MAX=835 AVE=237 MEAS=894 what do u think i should do? at the 25 mph one it passed at MAX=774 AVE=199 AND MEAS=764.... thanks let me know asap cuz i need to get the car smoged and reg...</TD></TR></TABLE>
did you read any i typed at all? read again, ur cat is lazy at 15mph, but when it picks up speed it actually starts to work again.
Old Jan 7, 2006 | 08:05 PM
LowTEC-JERMZ's Avatar
that is some good info from my area too
Old Jan 7, 2006 | 08:07 PM
crx91spoon's Avatar
If you lived over here in fresno it would pass for $250
Old Jan 9, 2006 | 12:21 PM
TEST ONLY's Avatar
Default Re: (crx91spoon)
The best way to pass the car is legally. There are plenty of legal ways to pass the vehicle at the smog shop. If you have any smog related questions, email me.
jdmsir96
Jun 15, 2008 10:48 AM
dc4teggiehatch
Mar 12, 2008 10:03 PM
out_of_order
10
Oct 9, 2004 08:50 PM
DIE DIE
Feb 27, 2004 06:30 PM
