SMELLs??
Old Aug 21, 2004 | 08:52 PM
wowee's Avatar
Default SMELLs??
whenver i drive my integra..and i get out..it smells like burnt clutch? but i dont burn clutch..is there any other smell that integra makes from faults?
Old Aug 21, 2004 | 09:00 PM
InTegRed81
Guest
Posts: n/a
Default Re: SMELLs?? (wowee)
do u drive yur car hard? and if so whens the last time u got yur oil changed? it could be tat. tats what happend to my friends car. and now he has to change it every 1000 miles. If its not tat then, is yur exhasut pipe bent?
Old Aug 21, 2004 | 09:14 PM
wowee's Avatar
Default Re: SMELLs?? (InTegRed81)
yea i need an oil change..
im suppose to get it after 3000 miles
but i didnt have time to but its only like 100 miles over or something..
so you think thats the problem?
Old Aug 21, 2004 | 10:10 PM
Dc2 Powered's Avatar
that happen to me when i first got my car.. then i got it oil changed and it no longer smell like burnt clutch
Old Aug 21, 2004 | 11:35 PM
IVI's Avatar
IVI
Default Re: (Dc2 Powered)
brakes overheating sometimes could have a smell similar to burning clutch.
Old Aug 22, 2004 | 10:19 AM
matman4444's Avatar
a few miles over 3000 is not bad at all, actual the manual usually says alot more then every 3k i think mine says like 5k or 7500
Old Aug 22, 2004 | 03:52 PM
lanojp1's Avatar
i have the same smell on my 01 GSR...thought it was the oil, changed it, didnt work...
then i had a faulty oil pan gasket...changed that and it still didnt go away...
the smell is around the master brake cylinder...so im still tryna find out what it is...
but it doesnt bother the performance of the car...weird..
Old Aug 22, 2004 | 03:58 PM
jaydeemmmm's Avatar
I experienced the same problem. I honestly still don't know what it is. This only happens to me when I redline/high RPM it a few times. People told me it was the brakes.
Old Aug 22, 2004 | 04:30 PM
iwannaboostmyteg's Avatar
Default Re: (lanojp1)
The smell could be a lot of things depending on how your car is setup. Like for instance if your lowered to low you can get tire rub which will make that burnt smell. The most common smell would be burning oil and this can be caused in a number of places where a leak could be present. I suggest just looking over everything and checking to see if there is a leak at all. I was lucky when I bought my teg because I had and still have 0 leaks. Sorry I can't be of more help but all I can say is that oil burning is the normal problem for people so check your hose's or anything that holds fluid as I'm sure that something is leaking somewhere.
Old Aug 22, 2004 | 06:29 PM
wowee's Avatar
Default Re: (iwannaboostmyteg)
i dont think it is because its lowered..there wasnt any smell before..
and my car is complete stock (2001 gsr).
how do u know if there is an oil leak? cause there isnt any oil dripping on the ground. so maybe oil change?
and if it is the brakes..how would u go about fixing it?
Old Aug 22, 2004 | 06:41 PM
96ls's Avatar
Default Re: (wowee)
i also get a similar smell out of my 96 ls. but it only started after i put my intake on, when i redlinr the car it sometimes smells like new exhaust..but it doesn't hurt anything. i think its weird, but its not hurting anything yet..
Old Aug 22, 2004 | 09:36 PM
Default Re: (96ls)
oil on the ground isn't the only way to tell an oil leak... you could be leaking it slightly say around your head from the head gasket and it burns as it fry's on the block or the headers. there's many ways that oil can burn like it could be burning in your cat. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96ls &raquo;</TD></TR><TR><TD CLASS="quote">i also get a similar smell out of my 96 ls. but it only started after i put my intake on, when i redlinr the car it sometimes smells like new exhaust..but it doesn't hurt anything. i think its weird, but its not hurting anything yet..</TD></TR></TABLE>
The reason you get the smell is because you have oil burning in your exhaust system somewhere most likely its building up in your cat thus the smell soon if you keep it up you'll start to get smoke and actual sputters of oil coming out your muffler.
Old Aug 23, 2004 | 07:04 PM
wowee's Avatar
so how would i go about cheakin if my oil is leaking inside? and plus some othere dude said it might be cause the exhaust is bent. i got my exhaust replaced because some sucka hit me from behind and bent my exhaust but got it replaced. would the problem be maybe that the body shop dude ddint do it right?
trowe
23
Mar 29, 2012 08:56 PM
creator1322
Sep 20, 2007 03:09 PM
TypeR324
Honda S2000
13
May 14, 2007 12:39 PM
slow99dx
16
Jun 12, 2005 03:44 PM
Ross2852
Apr 7, 2005 09:02 AM
