Slipping
Old Jun 26, 2007 | 10:02 AM
Guiltyr1's Avatar
Default Slipping
Ok guys - I am new here so, be gentle... I have a 1999 teg LS with 80,000 miles. I haven't had any issues with the car: However, recently when I accelerate, the engine or trans feels like it is slipping only for a couple of seconds - then it takes off. The slipping feeling has gotten gradually more noticeable and it only happens when going from a standstill. Any suggestions/ideas?
Old Jun 26, 2007 | 10:06 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: Slipping (Guiltyr1)
If its a 5spd your clutch probably needs to be replaced soon chances are its the clutch that came in the car in '99.
Old Jun 26, 2007 | 10:09 AM
Guiltyr1's Avatar
Default Re: Slipping (St Jimmy)
Sorry, it is a manual.. And I don't the the fluids (other than oil) have ever been changed....
Old Jun 26, 2007 | 10:12 AM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Guiltyr1 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, it is a manual.. And I don't the the fluids (other than oil) have ever been changed.... </TD></TR></TABLE>
Then you can change your tranny fluid while your changing your clutch, it will also benifit you too because it will make the tranny lighter
Old Jun 26, 2007 | 10:13 AM
Guiltyr1's Avatar
Changing the clutch - sounds pricey.. Any idea how to test for sure that it is the clutch? How much? etc...
Old Jun 26, 2007 | 10:17 AM
Exeed's Avatar
To test, put up ur E-brake. Try to let the car move. If it doesn't move, you need to change the clutch. Keep in mind that once it moves, stop immediately.
As for price, clutches can be a little pricey. But they range from 250-400 depending on which brand and what stage. Installation costs will vary depending on you area, you're just going to have to get a quote from any local shops or a honda dealer if there's any nearby.
Old Jun 26, 2007 | 10:21 AM
Guiltyr1's Avatar
Default Re: Slipping (Exeed)
Ok, let me get this straight, put the car in drive, pull up the brake and if the car is trying to go forward, it is not the clutch?!?!?
Old Jun 26, 2007 | 10:40 AM
Exeed's Avatar
put up the E-brake, put in 1st gear, slip the clutch, and try to make the car move. If it succeeds your clutch is accpetable (notice how I say acceptable, and not good).
Old Jun 26, 2007 | 10:42 AM
Guiltyr1's Avatar
Sorry to be a pain but, you do know it is an automatic...
Old Jun 26, 2007 | 10:51 AM
ac_attak's Avatar
Why did you say it was a manual tranny in the third post of this thread?
Old Jun 26, 2007 | 11:00 AM
VTEC_PRODUCTION's Avatar
Default Re: Slipping (ac_attak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak &raquo;</TD></TR><TR><TD CLASS="quote">Why did you say it was a manual tranny in the third post of this thread?</TD></TR></TABLE>
haha...if its manual change the clutch and the oil...its its auto then your tranny fluid is low...and it must be leaking or somthing in order for it to be low...so change the seal and the oil in the auto
Old Jun 26, 2007 | 11:02 AM
Guiltyr1's Avatar
Stupidity - I am at work and was doing something else at the same time...
This car is an AUTOMATIC - sorry about the confusion..
Old Jun 26, 2007 | 11:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
yikes man if the auto tranny fluid has never been changed, you definitely need to get a complete tranny flush done. I know there is a filter in there somewhere also, not sure if that needs to be changed or just cleaned. I don't know a whole lot about automatic transmissions.
Old Jun 26, 2007 | 11:45 AM
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">yikes man if the auto tranny fluid has never been changed, you definitely need to get a complete tranny flush done. I know there is a filter in there somewhere also, not sure if that needs to be changed or just cleaned. I don't know a whole lot about automatic transmissions.</TD></TR></TABLE>
i do know however...you can use a petroleum based spray i.e. carburator cleaner, to spray in the tranny to get all the crap out and there is a filter and possible a magnet in the bottom of the pan you need to clean also...if its slipping it means that it lost some oil so there is a leak and you should replace the seal...or it my be just so bad that it just needs to be flushed...i dont know you need to look under there and check it out...
Old Jun 26, 2007 | 01:43 PM
OC Geezer's Avatar
Default Re: (1 slo turbo)
I thought he said it was manual? Change the fluid!!
Old Jun 26, 2007 | 04:02 PM
Exeed's Avatar
Default Re: (InLtegSra94)
He was confused.
MrMug3n
Honda Civic (2001 - 2005)
13
Jun 12, 2011 07:30 PM
ERIC1
11
Oct 30, 2010 06:51 AM
WalkerGSR1
Sep 16, 2006 05:35 AM
timsch75
Dec 22, 2005 08:23 AM
VtecbOi
Apr 7, 2003 08:23 PM
