skunk 2 IM what is the diff.
Old Oct 3, 2004 | 07:15 AM
jrv2u's Avatar
Default skunk 2 IM what is the diff.
Ok so a friend of mine says he has a skunk 2 IM for my GSR, but then he said it's for all b-series. Correct me if im wronge but isnt there a diff. between the IM that goes on the b16,b18b,b17, and b18c5 and the gsr or do they all fit? He said it was on a type r or b16 cant remember.
Old Oct 3, 2004 | 09:13 AM
xTravBx's Avatar
Default Re: skunk 2 IM what is the diff. (jrv2u)
The Skunk2 IM for the B-series VTEC heads is different than the IM for the b-series NON-VTEC heads.
The VTEC IM's are intechangeable with each other.
You can interchange the IM's for the non-vtec heads with each other as well.
But you can't mix VTEC & NON-VTEC.
Make sense?
Old Oct 3, 2004 | 09:18 AM
garados's Avatar
Default Re: skunk 2 IM what is the diff. (xTravBx)
SKUNK2 RACING INTAKE MANIFOLD FOR 88-01 B16A-B / B17A / B18C5
S2-307-05-0290
SKUNK2 RACING INTAKE MANIFOLD FOR 90-01 LS/RS (B18A-B) / 97-01 CRV (B20B)
S2-307-05-0280
SKUNK2 RACING INTAKE MANIFOLD FOR 94-01 GSR (B18C1)
S2-307-05-0270
Just from this, I'd say that the gsr is different from the other vtec motors, and both the vtec models are different from the non-vtec models.
Old Oct 3, 2004 | 09:22 AM
Kendall's Avatar
The one that will fit the LS and B20 head will not fit anything else.
The one that fits the B18C1 will not fit anything else.
The one that fits the B16, the B17, and the B18C5 will not fit anything else.
The only exceptions to this rule are if you swap heads with something else.
Old Oct 3, 2004 | 11:28 AM
blake2001's Avatar
ya get it on your GSR b18 works best with skunk 2 thats what i got.
Old Oct 3, 2004 | 08:15 PM
jrv2u's Avatar
thanks for the help guys
Old Oct 4, 2004 | 08:16 AM
Gerbilo's Avatar
Default Re: (jrv2u)
Just letting you know, but i would not get that manifold unless you have other work on your car done. Otherwise the stock makes better power.
Old Oct 5, 2004 | 01:25 PM
jrv2u's Avatar
Default Re: (Gerbilo)
what do you mean, everyone i've talked to says get it what kinda work you talking about
Old Oct 5, 2004 | 02:19 PM
XtremeCarTuner's Avatar
Default Re: (jrv2u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrv2u &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean, everyone i've talked to says get it what kinda work you talking about</TD></TR></TABLE>
a.k.a Headwork and/or forced induction is when you can fully benefit the intake manifold.
The only big difference there is in the IM is bigger runners and a 64mm opening for the throttle. I got the IM and i cant really feel a big difference.
Old Oct 5, 2004 | 02:42 PM
Chris_Bye's Avatar
Default Re: (XtremeCarTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtremeCarTuner &raquo;</TD></TR><TR><TD CLASS="quote">
The only big difference there is in the IM is bigger runners and a 64mm opening for the throttle. I got the IM and i cant really feel a big difference. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerbilo &raquo;</TD></TR><TR><TD CLASS="quote">Just letting you know, but i would not get that manifold unless you have other work on your car done. Otherwise the stock makes better power.</TD></TR></TABLE>
yup don't get it unless you have some other work done or you will loose serious low end and will loose top end too but not as much as low end..
Old Oct 5, 2004 | 04:43 PM
JBBNJ609's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xTravBx &raquo;</TD></TR><TR><TD CLASS="quote">The Skunk2 IM for the B-series VTEC heads is different than the IM for the b-series NON-VTEC heads.
Make sense?</TD></TR></TABLE>
wrong , stfu if you dont know dont post
Old Oct 5, 2004 | 04:44 PM
JBBNJ609's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">The one that will fit the LS and B20 head will not fit anything else.
The only exceptions to this rule are if you swap heads with something else.</TD></TR></TABLE>
he is 100% right, listen to him
skunk2.com
Performance
22
Jul 11, 2013 10:56 AM
hondamama7894
Oct 27, 2006 07:33 AM
ernald711
Apr 19, 2005 11:41 AM
IloveAPC
Sep 8, 2004 03:46 PM
