Old Apr 1, 2015, 09:13 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Side view mirror install
Old Mar 5, 2002 | 01:42 PM
MacLeanQuinn's Avatar
New User
Default Side view mirror install
Can anyone give me detailed instructions on how to install my passenger side mirror? It was broken off and I have the power OEM replacement, I just have no idea how to install it. Any tips/diagrams/explinations or links would be hugely appretiated!
Thanks
Old Mar 5, 2002 | 02:46 PM
StyleTEG's Avatar
Default Re: Side view mirror install (MacLeanQuinn)
You have to pull the door frame off. http://www.team-integra.net/sections...?ArticleID=107 for detailed information on how to do that.
Once you have the door frame off, you can remove the black plastic housing on the inside of the door, directly accross from your mirror. This should just pop off with a screw driver.
Just disconnect the old wire clip, and remove the three bolts. It should come right off, install is just the reverse.
Old Mar 5, 2002 | 03:12 PM
IN VTEC's Avatar
The black cover piece on the inside behind the mirror housing looks like this:
Getting the door panel back on tho...that can be quite a pain.
[Modified by IN VTEC, 6:13 PM 3/5/2002]
Old Mar 6, 2002 | 07:08 AM
New User
Default Re: Side view mirror install (IN VTEC)
What makes putting the panel back on such a pain? Can one person do it? and how long do you think it will take? THANKS for the help!
Old Mar 6, 2002 | 07:12 AM
redteg1's Avatar
u don't need to take off the whole door panel!!! just remove the black piece and pull the door panel back a little if u cant find the power wiring...its soooo ez. and then just connect and rescrew in the 3 screws and ur done! wat is it with this "removing door panel" stuff? you DO NOT need to remove the door panel unless ur someone who's 7ft tall and have hands the size of baseball gloves
Old Mar 6, 2002 | 08:16 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Side view mirror install (redteg1)
You will have to use a wrench to reach one of the nuts if you don't remove the door panel, as the lowest one is below the level of the top of the door panel. I think it might be 8mm nuts.
Old Mar 6, 2002 | 12:03 PM
GSRaCeRbOI's Avatar
yeah i didnt have to remove the panel do install mine (some dumbass drove too close to my car WHILE IT WAS PARKED and crashed off the driver side mirror).. you just take out the triangle (it pops out when u pull on it).. then u unbolt the 3 screws.. either 10mm or 8mm i believe.. then disconnect the power plug.. n install is reverse
crxaddikt
Jun 20, 2011 04:15 AM
chris3k
Audio / Security / Video
Feb 7, 2006 02:51 PM
jlsmi2
Dec 24, 2003 07:30 PM
Stupendous Man
Aug 6, 2003 08:07 AM
T817
Jul 3, 2003 11:21 AM
