side marker install
Old Oct 3, 2005 | 05:32 PM
Jbunn2001's Avatar
Default side marker install
hey i need some help, i searched here and googled but i couldnt find a template or anything that showed measurements or anything on where to install jdm side markers. any info is appreciated thanksguys.
Old Oct 3, 2005 | 06:28 PM
ERIC!'s Avatar
Default Re: side marker install (Jbunn2001)
search. there is lots of stuff on this.
Old Oct 3, 2005 | 06:29 PM
ERIC!'s Avatar
Default Re: side marker install (elephantegra)
this should help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">yep I just replaced my imitation OEM sidemarkers w/ genuine OEM Stanley sidemarkers, the fit is like night and day difference!
Here's the pic I made:
I think in reality that 3/4" measurement is more like 1/2".
I also have a diagram showing the exact measurements of the cutout, but I can't find it on my computer at the moment.
What I did was remove the fenders from my car (actually I did the driver side one on my new black fender before installing it), drew the diagram at actual size in AutoCad and printed it out, then taped it to the BACK of the fender in the correct location. Then I used an Xacto to cut the paper diagram along the lines, which left score lines in the backside of the fender sheetmetal. Then I drilled a hole and used my metal nibbler from Radio Shack to make the hole.
When I made the holes on my old fenders, I was cutting from the back of the fender, having the nibbler poke thru to the front. Unfortunately this made a little paint chip off near the edges of the holes. On these fenders I made the marks for the hole on the backside so that I could stick the nibbler thru from the front and follow it along the lines on the backside so that it wouldn't chip the paint off. I put down masking tape on the front so the nibbler wouldn't scratch the paint, although my fenders need to be painted anyway so it didn't matter that much. HTH, I'll try to find the hole measurements.</TD></TR></TABLE>
Old Sep 16, 2006 | 06:19 PM
JDMkidMARC's Avatar
Default Re: side marker install (the.ERIC.show)
[QUOTE=the.ERIC.show]this should help.
[/QUOTE
thanks, but do have the one with all the measurments????
Old Sep 22, 2006 | 12:51 AM
.13lank.'s Avatar
Here is a link to help you out:
http://www.giuffre.com/persona...s.pdf
Also, I spoke to someone from passwordjdm when i was installing mine and asked for the exact measurements of where the sidemarker sits on the fender. I was told (this is what i went by as well with the help of the link above), from the very back part of the fender (where the fender meets the door), its 4.5 (4 1/2) inches and from the top of the fender (where the fender meets the hood), its 8.75 (8 3/4) inches.
Hope this helps.....PM if you have any problems. Good Luck!
nicoya_hyphy@yahoo.com
Aug 17, 2007 08:16 PM
est ICZR.
Jan 21, 2007 12:54 PM
Kengs
Honda Fit
Nov 16, 2006 03:46 AM
b18c-1
Jul 31, 2005 07:14 PM
-JSpecEk*9-
Jun 6, 2005 08:23 PM
