shuddering while braking
Old Mar 28, 2004 | 12:02 PM
projectTeG's Avatar
Default shuddering while braking
when im driving at like 60 mph and i go to brake my car shudders really hard, could this be from bad axles?
Old Mar 28, 2004 | 12:03 PM
LSTEG96's Avatar
Default Re: shuddering while braking (projectTeG)
rotors warped... replace
Old Mar 28, 2004 | 12:07 PM
..::91TEG-G2::..'s Avatar
Default Re: shuddering while braking (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">rotors warped... replace</TD></TR></TABLE>
or get them shaved at a break shop.. very cheap and still works as good as be4 they were warped
Old Mar 28, 2004 | 12:11 PM
projectTeG's Avatar
would there be any vibrations at high speeds, because my car doesn't do that
mugen92acintls's Avatar
Default Re: shuddering while braking (..::91TEG-G2::..)
What happens when you change your rotors and they are still chattering? I changed my rotors, pads, tie-rod ends, upper ball joints, and cleaned all of the brake hardware and they are still chattering. The only other thing I think it could be is how they stacked the new rotors at the store or that the calipers need replaced. I really need to figure that **** out!!!
Old Mar 28, 2004 | 01:49 PM
cjohnson_2's Avatar
Default Re: shuddering while braking (mugen92acintls)
did you use a torque wrench to put the lugnuts back on? If not thast your problem. you have to make sure they are an EVEN 80ft/lbs (i believe). if they are not you will get that shuddering.
Old Mar 28, 2004 | 02:47 PM
xSCTYGx's Avatar
Default Re: shuddering while braking (cjohnson_2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjohnson_2 &raquo;</TD></TR><TR><TD CLASS="quote">did you use a torque wrench to put the lugnuts back on? If not thast your problem. you have to make sure they are an EVEN 80ft/lbs (i believe). if they are not you will get that shuddering. </TD></TR></TABLE>
i dont torque my lugnuts 80ft/lbs evenly...i do it by hand and i dont have any problems at all...
but i had this problem with the civic i used to own...its def ur rotors man..pads were so low it was basically metal on metal and warped the hell outta my rotors...get those replaced asap!
Old Mar 28, 2004 | 03:44 PM
xplanetearth420x's Avatar
Default Re: shuddering while braking (2Gen91Teg)
wharped rotors
Old Mar 29, 2004 | 06:23 PM
Default Re: shuddering while braking (xplanetearth420x)
But when I buy brand new rotors they still chatter.
JDMproblem
17
Apr 6, 2007 04:26 PM
globy123
Jan 22, 2007 07:37 PM
jorge99hx
25
Dec 10, 2005 12:52 PM
Takashi1978
May 23, 2005 05:26 PM
2k1 itr
Sep 15, 2003 06:59 AM
