Should i boost?
Old Feb 15, 2005 | 09:49 PM
silverslicks's Avatar
Default Should i boost?
Sup guys, just picked up a 97 gsr with super low miles. 44,000 original mileage. Wondering if i should boost my car. Would it mess my motor up that bad in the long run ?
Old Feb 15, 2005 | 09:51 PM
Kendall's Avatar
Do you want to boost it?
Old Feb 15, 2005 | 09:52 PM
anthonyyy's Avatar
Default Re: Should i boost? (silverslicks)
just sell it to me instead.
Old Feb 15, 2005 | 09:58 PM
ProjectDarkBlack's Avatar
Default Re: Should i boost? (anthonyyy)
when boosting your car at low boost 5-8 psi expect around 90% of engine life
Old Feb 15, 2005 | 11:25 PM
Deluzional's Avatar
Default Re: Should i boost? (ProjectDarkBlack)
Its your car, do as you please
Old Feb 15, 2005 | 11:28 PM
jBj's Avatar
jBj
i say if you wanna have a lot of fun with your fairly fresh car, boost!
Old Feb 15, 2005 | 11:44 PM
2.0T4's Avatar
Only if you plan for the unexpected, have a built motor, have a lot of $$ + patience, or boost really low psi....then if your're not certain w/ any of these, then don't boost.
Old Feb 15, 2005 | 11:59 PM
CRX_1.8T's Avatar
Why not I say... Just as long as you don't drive like a total jackass and keep the car maintained well, you should be ok man.
Old Feb 16, 2005 | 07:06 AM
cnydc2's Avatar
It is all in the tuning. You could run 7-8psi everyday and not have any problems,as long as your car is properly tuned. I say go for it.
Old Feb 16, 2005 | 07:33 AM
jdm phantomx's Avatar
Default Re: Should i boost? (cnydc2)
if you have the money to piece together/buy a turbo and properly tune it then by all means do it
Old Feb 16, 2005 | 07:46 AM
qcktegls's Avatar
Default Re: Should i boost? (broken sword)
its all about the $$$ and how long u want the car to last. if you want it to last a good while then even if it is turbo'd u still have to drive it easy. if its not tuned right and u punch it every chance u get ur gonne be investing in a new motor or new car
Old Feb 16, 2005 | 07:54 AM
PearlWhiteAccord's Avatar
Default Re: Should i boost? (qcktegls)
boost it...hehe if u have money
Old Feb 16, 2005 | 08:42 AM
RuskeR's Avatar
As everyone has said, you can boost it at 7-8 psi and the engine will still last a long time.
However, it sounds like you need to learn a bit more about turbos before you go and boost your teg. It will save you ALOT of money in the engine. More than likely, it will save your engine.
Old Feb 16, 2005 | 10:31 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: (RuskeR)
It's not about PSI X number levels that draws the line in blowing up your motor or still keeping it safe.
It's proper turbo sizing and the resulting WHP or target goal you want.
EX: 250WHP on a T3 turbo @ 10-12 psi vs 250WHP on a T3/T4 turbo @ 6-8 psi.
The powerbands may slightly differ from each other, but in the end, they are both making roughly the same HP.
AND **** YES, boost your motor. Research first please.
2percent7
Jun 4, 2008 04:16 AM
aalb1
Nov 15, 2005 02:09 PM
B16Civic93
Jul 13, 2005 02:12 PM
espanol
Mar 13, 2003 09:23 AM
incognitoracerr
Jan 10, 2003 05:42 PM
