Short Shifter Install
Old Dec 25, 2002 | 02:44 PM
Integra21's Avatar
Default Short Shifter Install
i got all of the directions and everything - but i dont know how hard it will be-
How difficult is it and how long should it take for me to do it??
Thanks,
Brad
Old Dec 25, 2002 | 02:51 PM
Pineapple Devil's Avatar
Default Re: Short Shifter Install (Integra21)
difficulty 1-5 is a 2 1/2
time depends on your mechanical ability and if you have it on jackstands or a lift
Old Dec 25, 2002 | 03:25 PM
Integra21's Avatar
Default Re: Short Shifter Install (Blake)
now did you remove the shift linkage?? because ive read that you can remove it but you dont have to
Old Dec 25, 2002 | 03:35 PM
tegasaurus's Avatar
took me 20 min.. with no instructions..
after the center console was taken out, the only tough part was getting a socket/extention combo that would fit around my greddy evo piping to disconnect the shift linkage from the shifter.
beware of the two "bolts" that hold the shifter into the frame... they will take about 5 min each with 2 people.
good luck. What brand shifter did you end up getting?
Ryan
Old Dec 25, 2002 | 04:16 PM
Tweakmeister's Avatar
Default Re: Short Shifter Install (tegasaurus)
http://www.overboost.com has an article (search).
Old Dec 25, 2002 | 05:52 PM
8k's Avatar
8k
the hardest part is working around the exhaust pipe. pretty easy work, took about 45 mins. with a smoke break
Old Dec 25, 2002 | 05:55 PM
integranator's Avatar
Default Re: Short Shifter Install (8k)
Just Unbolt the Exhaust where it connects to the cat, then its smooooth sailing!
Old Dec 26, 2002 | 07:50 AM
Integra21's Avatar
Default Re: Short Shifter Install (integranator)
i havent decided on a certain on yet - still trying to decide - any suggestions?
Old Dec 27, 2002 | 01:29 AM
hatchback's Avatar
c's.
Old Dec 27, 2002 | 08:06 AM
01redgsr's Avatar
Default Re: Short Shifter Install (hatchback)
took me about 30 mins, i had a lift to use, and it is much easier to unbolt the exhaust then it is to work around it.
nicoya_hyphy@yahoo.com
Sep 7, 2007 08:26 PM
hwtfan
Nov 21, 2004 07:57 PM
elevatethis
27
Aug 10, 2004 11:12 PM
RFX
Jan 24, 2002 09:32 PM
erikjohn19
Sep 28, 2001 10:48 AM
