shifting probs
Old Dec 10, 2003 | 08:41 PM
SnkyPY's Avatar
Default shifting probs
i am having some probs shifting it is really hard to put into gear and SOMETIMES when i force it it grinds. any suggestions, i know my tranny fluid is thin, could that be a main prob?
Old Dec 10, 2003 | 09:36 PM
88civicHB703's Avatar
does this start recently when the weather got cold? and sometime it doesnt seem to go in gear right. i have a similar problem no clue why..
Old Dec 10, 2003 | 10:05 PM
Boges's Avatar
Default Re: shifting probs (98TegKid)
First step would be to change the transmission fluid. What do you mean by thin?
Old Dec 10, 2003 | 10:26 PM
oemDC2's Avatar
Default Re: shifting probs (Boges)
The best thing to do is, change your transmission fluid first, over time shavings from your gears start to build up between the syncros which makes it difficult to shift into gears. If changing the tranny fulid still doesnt work, its probably your syncros..
Old Dec 10, 2003 | 10:28 PM
Dan GSR's Avatar
Default Re: shifting probs (oemDC2)
if it has problems in every gear....its mostly likely your clutch/pressure plate
Old Dec 11, 2003 | 07:02 AM
SnkyPY's Avatar
Default Re: shifting probs (Dan GSR)
maybe i should put my itr clutch in? wanan get a flywheel b4 tho.
Old Dec 11, 2003 | 09:16 AM
EL Vap133's Avatar
When was the last time you replaced your clutch?
kpjo4
Apr 30, 2010 06:52 AM
nmb16a
Transmission & Drivetrain
Jan 31, 2010 07:43 PM
hojoR
Aug 16, 2009 08:32 PM
phoshizzle88
May 17, 2006 10:39 PM
machine4321
Jun 1, 2003 10:41 PM
