Shifting Problems again
I have a 1994 inregra ls. The Clutch finally wount disengage. Its a ACT stage 4, 6 puck clutch with maybe 4,000 miles on it. I have replaced the slave and master cilinder. There is no leakes any where and theres plenty of fluid. I did not bench bleed the master cilinder. I used to be able to pump the clutch when car was off to put it into first but that does noting at all. Its inpossible to put the car into gear since the clutch wount disengage.You can be driving with the gas pedal to the floor an push the clutch in and out a bunch of times and nothing happens. Im thinking im going to pull tranny tomorrow to look at the throw out bearing and the Y arm. ANY ideas what it coule be.
s13hero
14
Nov 21, 2010 04:57 PM
Beach Accord
Feb 2, 2003 05:45 PM
